Sponsored by:
Sponsored by: CARiD
P0172, P0175, possible tuning needed to fix?
Old Sep 23, 2009 | 03:14 PM
TDotMax's Avatar
Post in 5th gen section put perhaps I can get a more "advanced" reply here. Reason is I'm wondering if these codes are simply because I run rich after 3200rpm? I'm having a few parts installed and getting a dyno tune done. Could the dyno potentially correct these codes I'm pulling?
Thanks,
http://forums.maxima.org/5th-generat...r-3200rpm.html
Old Sep 23, 2009 | 10:09 PM
MoncefA33's Avatar
It shouldn't be a problem unless the car is rich in closed loop. What AFRs is your car reading in part throttle/cruise?
Old Sep 24, 2009 | 05:54 AM
TDotMax's Avatar
14.5 around there, but just giving it a little more gas then it goes to 13's, then 12's to 11's at WOT
Old Oct 5, 2009 | 08:37 AM
TDotMax's Avatar
Any other ideas before I dump money into O2's I may not need?
Old Oct 5, 2009 | 09:34 AM
DandyMax's Avatar
3.5 in the works
Kev if you need to confirm the health of your O2 sensors, watch their waveforms on an OBD scanner such as the Auto Enginuity Ray has, you'll be able to watch them cycle in closed loop and the voltages also which will tell you what they're doing.
Old Oct 5, 2009 | 09:36 AM
DAVE Sz's Avatar
Hooooooonda.....
the O2s do nothing after 3000rpm, why are you replacing them? If you were lean or rich at idle then I would understand.
did you tune the car like you said you were?
Old Oct 5, 2009 | 11:42 AM
TDotMax's Avatar
Thanks Dan,
That does help.
Dave thanks for letting me know they do nothing after 3000. I haven't had it tuned yet. A lot of delays on getting around to the mods. Hopefully soon enough. My sensors are only 1.5 years old maybe 2 tops.
smplyamzng
Dec 13, 2015 01:19 PM
Finkle
Sep 27, 2015 09:53 PM
t6378tp
Aug 24, 2015 07:03 AM
TonyJr
Aug 20, 2015 12:14 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
