Sponsored by:
Sponsored by: CARiD
Pathfinder throttle body install write up
Old Mar 8, 2010 | 04:06 AM
TDotMax's Avatar
Tried searching and could not locate. If someone can provide a write or quick instrucions. Thanks
Old Mar 8, 2010 | 07:23 AM
915Max's Avatar
Are you referring to a PF throttle body??
Old Mar 8, 2010 | 02:43 PM
TDotMax's Avatar
Sorry, meant tb
Old Mar 10, 2010 | 11:52 AM
ajcool2's Avatar
Buy Stephenmax's adapter plates and bolt it up or drill new holes through the TB and make it fit.
Old Mar 12, 2010 | 11:20 AM
TDotMax's Avatar
I know it can't be that easy. I already have a plate, well it's just a spacer so the it clear the VIAS. After that is it just plug and play? Also what about the coolant bypass?
Old Mar 13, 2010 | 01:55 PM
TDotMax's Avatar
Found it. Now I don't have a coolant block off plate so I might just not bother with a bypass for now.
But does anyone have a pic of the TPS? As I understand the best way is to swap the pathfinder TPS out and use the Maxima one.
Thanks,
Old Mar 23, 2010 | 04:59 PM
TDotMax's Avatar
Ok getting things together now. As for the IACV I realized not to block it off on a 5th gen. But what I can't find out is if I use the 5th gen IACV or the Pathfinder one?
Old Mar 23, 2010 | 07:00 PM
schmellyfart's Avatar
Either one will work in the PF IACV housing. Right now, Im running a PF IACV in the 5th gen IACV housing.
AcuraLegend
Sep 22, 2015 04:22 PM
MaxLife17
Sep 8, 2015 02:36 PM
Johnny9595
Sep 3, 2015 05:18 AM
Maximeltman
Aug 31, 2015 01:01 PM
Samedi
Aug 13, 2015 04:05 PM
