Sponsored by:
Sponsored by: CARiD
Engine Work
Old Jan 17, 2011 | 10:19 PM
BIG D MAXX's Avatar
Engine Work
I have a quick question..... Can the VQ30DEK or VQ35DEK can be bored out and if they can how much? Im not that into forced induction or spray... just trying to get more ponies out of her ... Thanks for the help n time
Old Jan 17, 2011 | 10:29 PM
perkman87's Avatar
you can bore anything out.
Old Jan 17, 2011 | 11:39 PM
NiZMo1o1's Avatar
Never heard of a VQ35DEK
but yea it can be bored out and stroked.
Why dont you check out this guys motor
http://forums.maxima.org/general-max...na-vq35de.html
Old Jan 19, 2011 | 09:48 AM
BIG D MAXX's Avatar
Thanks for the info.... Would yall how much it cna be bored out.... and where can i fine the parts for it like pistons n cams etc.?
Old Jan 20, 2011 | 10:53 AM
NmexMAX's Avatar
dot dot dot ...
Any reason you're hell bent on 'boring it out'?
Old Jan 20, 2011 | 03:23 PM
doublea's Avatar
If I ever blow my DEK engine, I will sleeve a VQ35 block, the advantage with sleeve is it's very strong so you can bore more without affecting the strenght so you can bore it to the extreme. I think it is possible to bore the block by 20-30 thousand of a inche at and still have a strong engine over that and your playing with fire.
Old Jan 20, 2011 | 08:59 PM
NiZMo1o1's Avatar
Weight reduction my son ! weight reduction
Old Jan 21, 2011 | 11:51 AM
asand1's Avatar
Your going to bore an aluminum cylinder to fit a bigger aluminum piston. Where's the weight savings?
Old Jan 21, 2011 | 12:48 PM
NiZMo1o1's Avatar
Really ? The VQ is made out of Aluminum ??????????
Its called sarcasim asand1 , check my join date , I wasnt just born 1-21-2011...
( acutally I was born in 1-18....)
Old Jan 21, 2011 | 01:18 PM
ajcool2's Avatar
lol
Old Jan 21, 2011 | 04:20 PM
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
At most without sleeving (VQ35), you could probably go to 97mm max. Not a big gain over 95.5mm, and I'd just stick with .20 over (96mm) if you're going to build it for anything more than NA and don't want to spend a wad on sleeving it. With sleeves, 100mm is doable. Even then, not much to be seen for power gains.
Old Jan 22, 2011 | 03:30 PM
asand1's Avatar
Join date doesn't mean squat, and sarcasm doesn't communicate well in text form. Why not just swap cams, unless you already have.
Old Jan 22, 2011 | 09:17 PM
NiZMo1o1's Avatar
your probally one of the guys that take everything in life so serious that you dont have time to wipe your @ss , jeeuz take a joke GUY!
Old Jan 23, 2011 | 11:14 AM
asand1's Avatar
Not really. I've seen people with 3,000 posts ask how to change there oil, and your post about weight savings sounded like a legit post. My mistake, not being smart or arguing.
That said, what about a stock 3.5 bore and stroker crank. Welding additional metal to the outer circumfrence of the rod journals and re-machining for an extended stroke. They do it with V-dubs and the same shops should be able to do VQ. Thats if you cant buy a stroker crank aff the shelf, IDK. And then youd need shorter rods or custom pistons. I haven't looked into any of this.
Old Jan 23, 2011 | 12:24 PM
There are several options for off the shelf stroker parts for the VQ35DE.
Old Jan 23, 2011 | 01:27 PM
NiZMo1o1's Avatar
The Fact of the matter is , the OP hasnt replied back and what his goals is.
Old Jan 25, 2011 | 12:03 AM
MIKERNM1990's Avatar
Stroker kit have more power. but i not know about Higher Compression (All-Motor Only) can gain power?
Old Jan 25, 2011 | 05:08 AM
My post went over your head. Just give up....
Old Jan 25, 2011 | 12:06 PM
ok well, I wonder when i post, owner not get back on me?
Old Jan 25, 2011 | 12:08 PM
Crusher103's Avatar
I vote ban.
Old Jan 25, 2011 | 12:10 PM
I vote ban.
Thank You, maybe this user not support to me?
Old Jan 25, 2011 | 02:46 PM
ajcool2's Avatar
lol
Old Jan 25, 2011 | 03:05 PM
Aren't there like 50 different honda forums out there that you can go troll instead of this one?
Old Jan 25, 2011 | 03:44 PM
BIG D MAXX's Avatar
Like i said im no fan of Forced Induction or spray....Just trying to get as many ponies out of it as i can....
Old Jan 25, 2011 | 05:44 PM
Crusher103's Avatar
^Ban him too.
Old Jan 25, 2011 | 07:12 PM
NiZMo1o1's Avatar
how deep are your pockets ?
how much are you willing to spend to acheive your goals N/A ?
lmk when your ready and I got a set of Jeveny ITBs for your 3.5 !
Old Jan 25, 2011 | 09:26 PM
BIG D MAXX's Avatar
not real deep but its a 3.0
Old Jan 25, 2011 | 09:38 PM
If your pockets aren't real deep, then boring/stroking seems a little out of the question. Do you already have full boltons, tuning (real tuning, not an AFC) and cams? Considered swapping a 3.5 bottom end?
Old Jan 25, 2011 | 10:12 PM
BIG D MAXX's Avatar
nope gonna start fresh on it
Old Jan 25, 2011 | 10:38 PM
NiZMo1o1's Avatar
You need to set a goal , budget yourself , and alot of research then if your starting from *fresh* scratch
Old Jan 26, 2011 | 12:06 AM
im not troll.
Old Jan 26, 2011 | 05:51 AM
essential1's Avatar
My axles cry for mercy...
Shallow pockets, and boring out a motor do not go hand in hand. If you want to increase displacement without breaking the bank, get a 3.5 with bolt ons and a tune and call it a day.
Old Jan 26, 2011 | 07:57 AM
Seriously... When you are starting with a 3.0, a 3.5 short block is literally a bolt in stroker kit on the cheap.
Old Jan 26, 2011 | 08:15 AM
Crusher103's Avatar
Although its cheaper and easier to just buy a 3.5......just stock NA 3.5, Tune and leave it alone.
Old Jan 26, 2011 | 09:05 AM
BIG D MAXX's Avatar
alright thanks for the advice n tips....
Old Jan 26, 2011 | 09:15 AM
Good luck. You know... If you're really dedicated to making big NA power, keep your car at stock height and have some custom long tube headers made by a pro fabrication shop with a nice mandrel bender. Around 1.75" diameter, 30" long primaries would be optimal for one of the "normal" 272ish cam options....
Old Jan 27, 2011 | 04:37 PM
TDotMax's Avatar
LOL, I don't think he is dedicated, but this thread was a good read
maxinout93
Oct 27, 2015 01:29 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kenc15
Aug 5, 2015 08:29 AM
