Sponsored by:
Sponsored by: CARiD
02 SPEC V Tranny Swap, What Can I Use/What Do I Need? 4th Gen
Old Feb 14, 2011 | 11:33 AM
OC_Nooby's Avatar
Hey Guys,
Was searching around and found a 2002 Sentra SER Spec V car minues the motor, but I care about the tranny.
So lets start off with what I need.
REQUIRED PARTS
02+ 6spd maxima transmission. sentra spec-v will also work (if you use maxima bellhousing)
5.5 gen 6spd maxima shifter assembly
5.5 gen 6spd maxima shifter cables
6spd drivers side axle
6spd pass axle*
6spd frame trans mount
6spd transmission mount
6spd flywheel
6spd clutch
5spd timing ring
6spd starter
6spd slave cylinder
What can I salvage from the car? what will I need to get? Its going into a 4th gen 3.0. I have an auto timing ring if that helps.
I need to know if I should jump on this or not. Thanks
Old Feb 14, 2011 | 01:05 PM
aackshun's Avatar
Get the transmission of course, and cables and shifter, maybe my shifter is what's causing all of my problems since it's a maxima shifter with sentra cables....
Old Feb 14, 2011 | 02:58 PM
OC_Nooby's Avatar
axles would be to short? motor mount no good? I know I'll need a 5.5 bell housing. If all I can salvage is the tranny + shifter it wouldn't be worth it.
stevesmax
Dec 17, 2020 11:57 AM
Matt93SE
May 24, 2019 02:58 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
Finkle
Sep 27, 2015 09:53 PM
Supragte
Aug 12, 2015 10:00 PM
