Sponsored by:
Sponsored by: CARiD
What else would make a maxima not start?
Old Jul 30, 2011 | 10:00 PM
max95q's Avatar
Ok, given it has a new starter, battery, position sensors cam and crank, and new ignition switch. I still have my old 95 that was rear ended 2 years ago in my garage. What would make the car flash all lights and die while driving then wont start back up after that?
Old Jul 31, 2011 | 08:03 AM
MOHFpro90's Avatar
How long does it usually drive before this happens? Will it start after a period of waiting? And by flashing all the lights, you're referring to the gauge cluster lights, correct?
Old Jul 31, 2011 | 03:43 PM
Product_Of_Korea's Avatar
so when you try and start it back up does anything come up on the dash(lights)? How do all the grounds look? Particularity the ones that sit on the lower intake manifold?
Old Jul 31, 2011 | 06:05 PM
max95q's Avatar
All lights come on for the dash. It will crank but that's it. I'll check the grounds.
Old Aug 2, 2011 | 05:07 PM
94VEmaxpax's Avatar
bad ground somewhere for sure. possibly somewhere with a lot of vibration causing the flashing lights possibly.
Old Aug 2, 2011 | 06:14 PM
MOHFpro90's Avatar
How do you get it started again? Wait a period or time?
Old Aug 3, 2011 | 04:56 PM
accordingtou's Avatar
VQ30 DE T
Bad connection. check (wiggle test) engine harness from batt all the way to ecu. ecu may also be on fritz..
MAXSE5SPD
Aug 23, 2015 12:06 PM
cmpowell86
Aug 10, 2015 12:35 AM
kirkhilles
Aug 8, 2015 10:53 AM
Blackwind
Aug 5, 2015 06:35 PM
Jcof88
Aug 3, 2015 10:43 PM
