Sponsored by:
Sponsored by: CARiD
Quick 'n Dirty DE-K Build.........
Old Dec 18, 2011 | 10:41 AM
KRRZ350's Avatar
Guess the HP after tune, winner will get a prize!
Just finished putting a cammed motor together for my friend, after a few minor issues typical to '00vi swaps, we got it fired up yesterday!! This entire build was put together & installed in just a few days. It idles great with no IACV, around 950, tried plugging in the 5th gen iacv backwards- THIS IS THE 3rd CAR I'VE TRIED THIS ON, shlt just doesn't work for me
This vid is it revving to approx. 4K rpms, in the coming months we will install an EU and spin it up on the rollers to 7,700 rpms & hopefully make some good numbers Will upload in car video very soon once clutch is broken in, stock limiter for a little while though guys.
I've gotta say, it sounds sweet but really doesn't thump anywhere near what a 3.5L does with these cams, oh well- I still hate 3.5's
http://www.youtube.com/watch?v=lCvAFe4PSJ0
Dave's work in progress, quick run down on the current mod's for this junkyard rescue are-
*30K mile de-k
*Deluboz 3.5l s1 knock off cams w/stephen max adaptors
*HR springs & retainers, double shimmed
*Rev-up oil pump
*E-bay OBX equal length 5.5 gen headers (good)
*E-bay N1 2.5" mandrel bent catback (not good) (looking to source a used cattman 3")
*freshly rebuilt VLSD 5-MT
*ACT HD 6-puck
*Tein coilovers
QUESTIONS-
-Car is currently running on stock fuel system, will this suffice for stock limiter?
-The adapter I used for the inlet side of the rail consists of a section of hard line from a 3.5l pathfinder, it has a nasty [from the factory] kink in it, I know some of you are familiar with this bottle neck I am talking about, IIRC it's there somewhere on practically every fuel rail, but I don't think on the inlet to both banks like it is on this car. Will one of those weapon-R or similiar rail adapters be mandatory even before we go past the stock limiter?
- Think 7,700 rpms is a lucky number or what?
Old Dec 18, 2011 | 12:04 PM
taz394's Avatar
200-210 hp
and the answer to solve all your problems is a simple real VQ35 swap and you would be much faster
/thread
Old Dec 18, 2011 | 12:59 PM
McSteve's Avatar
good job, where did you score the cams at?
Old Dec 18, 2011 | 01:04 PM
98SEBlackMax's Avatar
Maxima.org Insomniac
Kind of curious on how this turns out. Been wanting to cam my DEK for some time now and install the upgraded oil pump thats been sitting in a box for years.
On the last DEK swap I ended up rewiring the harness on the 4th gen IACV and using a 5th gen IACV plug. This was on Dan Mack's car and his stuff works fine with no cold start issues and no codes, except for an IACV code once in a while.
Anyways the power depends on the dyno as to the numbers you put down, but I would say on a Dynojet248C 225~235 WHP is possible with a tune. My DEK swap put down 222 WHP @ 6600 rpm redline on a 248C and this was with stock DEK cams. The DEK makes power to redline so with this new setup it still should make power, so 7500 ~ 7700 should be a good rev limit to shoot for with the hotter cams. You might want to remove the power rod if your gonna rev that high.
If your running the DEK fuel system I recall its 280~290 CC with the 4th gen FPR? As long as the fuel pump is still good that should be enough for the power this will put down. I still have plently of fuel on my setup with stock DEK injectors and AFPR.
Watch for any kinks in the hoses as these can break the hoses over time. The fuel rail on my car has a metal fuel elbow TIG welded to the rail so the rubber fuel lines can be kept short and no kinks in the hoses.
Old Dec 18, 2011 | 01:11 PM
BigLou55's Avatar
sounds really good...nice work!
Old Dec 18, 2011 | 01:16 PM
KRRZ350's Avatar
Straight from delubozparts.com, though I recently saw a gently used set on e-bay for $400
Originally Posted by taz394
200-210 hp
/thread
Status: p*****t
Buy a car with a manual transmission, it will solve all of your problems.
Thanks for the info, appreciate the heads up on the fuel lines, I've seen the return lines get collapsed several times & agree there.
I think you'll be surprised at what the cams + 1k rpms will do, but we'll have to wait & see.
Old Dec 18, 2011 | 02:10 PM
Crusher103's Avatar
*30K mile de-k
*Rev-up oil pump
*ACT HD 6-puck
*Tein coilovers
QUESTIONS-
IIRC it uses 290s if its a DEK injectors&rail, i dont think it would need more than that. Maybe pick up a AFPR and raise the FP a bit. You have a wideband on the car?
200-210 hp
/thread
I hope this was a joke, that motor will most likely put down MORE than a stock VQ35. Learn what you are talking about before opening your mouth again.
Old Dec 18, 2011 | 02:40 PM
McSteve's Avatar
hmmmm 699 plus shipping from debulozparts... i saw BC on sale for 960... I'm debating not doing the Rev-up anymore and going for bigger cams while i'm at it...
Old Dec 18, 2011 | 02:41 PM
t6378tp's Avatar
Turbo 3.5
r u using standard Stephenmax cam timing or something you requested, any port work, pftb, cutout
My guess is 237
Old Dec 18, 2011 | 05:01 PM
aackshun's Avatar
I hope this was a joke, that motor will most likely put down MORE HP than a stock VQ35. Learn what you are talking about before opening your mouth again.
Fixed. DEK is still a TQ-less wonder to behold.
Old Dec 18, 2011 | 05:12 PM
Crusher103's Avatar
.....tq less? It doesnt have as much torque as the VQ35 but tq-less? You need to lay off the pipe.
Old Dec 18, 2011 | 05:29 PM
aackshun's Avatar
Wait for this guy to dyno, I'll show ya, since Dandy's dyno's are down, this DEK should be making some good enough numbers for it to show up.
Old Dec 18, 2011 | 06:21 PM
036mtmax's Avatar
Nice work as usual Kev, Im going to say tuned on EU pulling to 7700 with a 3'' C/B should be 245/250 hp
Old Dec 18, 2011 | 07:31 PM
KRRZ350's Avatar
3.5's have torque, sure, we all get that, was waiting for someone to say it actually. But 3.0's are bulletproof & they have this ultra smoothness to them that's hard to explain but the 3.5 lacks it, and I like that. Not my car so I don't care either way, but I personally don't like 3.5 swaps at all.
On my bone stock '96 auto (Which has some decent oil leaks) I go 10K miles (rotella T6) between changes, it has 250K on it, and it only loses a 1/4 of a quart in those 10k. It's bone stock but I wail on it & lend it out to people for 50% of those miles.
U mad I don't even look at my dipstick for several months?
My guess is 237
Standard. No portwork, never removed the heads either or I would have done some other stuff. At some point I will at least match the 00vi upper to TB as this area is horrible & easy to address.
Old Dec 18, 2011 | 08:06 PM
MoncefA33's Avatar
get off the VQ35's d1ck for a minute.
In for results...
Old Dec 19, 2011 | 04:09 AM
DrunkieTheBear's Avatar
Turbo'd Saab
238whp
Your still alive? HOLY CRAP!
Old Dec 19, 2011 | 05:07 AM
MAXIMA_STYLE's Avatar
I will agree... dek is alot smoother engine and less prone to problems but im going to guess and say 242... ive been waiting for someone to post up a new thread like this...ive always wanted to cam my engine. And the fact hes only a state away makes it thattt much better
Old Dec 19, 2011 | 11:21 AM
taz394's Avatar
1) 238 whp ? thats it lol ? how is that more then a bolt on VQ35
2)my fully built tranny alone probably costs as much as your whole car
3)i let off in my car as soon as i get into 4th gear and still run 1-2 seconds faster then you in the 1/4 LOL me joining in 2010 means youre really really slow (moncef)
4)how much have you spent in this car ? my friend in his bone stock 01 put a vq35 and went from urnning 15.0 to a 14.0 flat with a $700 motor and a straight pipe
Old Dec 19, 2011 | 11:32 AM
aackshun's Avatar
HEY IT WAS A 14.9!!!!!! and it was a AE (Cali spec even but didn't he have the fed spec conv. done already??) +5hp, Ithankyou
But this is besides the point... Point is we want dyno #'s and track times and 7.7krpm shifts
And we fully understand why you like the 3.oh'z now, I <3'd mine, cept the fact it was lacking in the power dept, but not short on toughness, I highly doubt a 3.5 would have lasted as long under the same brutal conditions my 3.0 lived through like a bawsss.
Old Dec 19, 2011 | 04:02 PM
036mtmax's Avatar
Old Dec 19, 2011 | 04:08 PM
bamboomerang's Avatar
Gotta love junkyard sleepers.
without knowing the details of all the little things, i'm loosely guessing low 230's - considering the power valve and a less than ideal intake setup will rob about 8-12 hp a piece at those revs.... and 7700 will blow that pump soon enough - 3.0's need balancing.
Is this with stock pulley/power steering/stock flywheel/sawblades?
Old Dec 19, 2011 | 05:03 PM
036mtmax's Avatar
Who are you to talk about anyone's car dude ? You struggled to break into the 12's with all this stuff done to your autotragic 6th gen . Fully Built Level10 5AT + 11:1 Compression Ceramic coated pistons/Eagle rods + Bored block + Fully ported Heads + JWT S7 cams/ valve springs + Stage 2 Nitrous wet shot system + NGK 2 Step Colders + Zex Bottle opener + Dynotune bottle warmer + AEM Uego wideband + Custom Headers/Y pipe + RL Strut Bar/Aluminum MM's/Grounding kit + Catback Exhaust + Ported IM/Elbow + K&N CAI + NWP BOP/IM spacers + 07 Rear bumper + Nitto555R's + D2 Racing Coilovers + D/S Rotors + more Here comes the bullsh!t excuses now
Old Dec 19, 2011 | 06:02 PM
blue_magicSE's Avatar
It actually sounds decent for a ebay catback and headers..
id say it'd put down a little north of 230whp.
Interesting debulozparts are making cams again for the 3-5 ... they were no where to be found a cpl years ago .
Old Dec 19, 2011 | 07:01 PM
McSteve's Avatar
self-edit for own stupidity and lack of reading comprehension
Old Dec 19, 2011 | 07:57 PM
nismomaxct's Avatar
You're alive. And I think I saw this car on the road the other day...maybe sunday? My guess is 255 hp. O and I will be calling you for a dyno setup soon...
Old Dec 20, 2011 | 12:38 AM
Turbo'd Saab
Wow how did some Noobs turn this thread into a **** storm WTF?
Anyways, I still contend that 300whp is possible on the ol' 3.0, if your willing to blow the money and what not and probably have to run E85 to do it.
I did forget that Dandy did break in at 272whp IIRC with the 3.0.
Old Dec 20, 2011 | 06:24 AM
aackshun's Avatar
No he didn't run the 12.9 with that stuff, the 12.9 was on a pretty stock motor + nawwzzzz.
You should read his thread, he list the mods in it.
That's just what he has in parts laying around now.
Certainly don't doubt it, but at that point in time it looks like a Honda making 300whp, and you've spent all of your money to turn your car into a Honda w/ a Nissan logo.
Don't understand what I'm sayin? Wait till this car dyno's.
To KRZZZ
Was there any bottom end work done? Or are you gonna goto 7.7k w/ a Stock Bottom End???
Also stock fuel rail for a DE-K???
Old Dec 20, 2011 | 11:01 AM
Crusher103's Avatar
meh, my ***** is bigger than yours......
Old Dec 20, 2011 | 11:06 AM
Crusher103's Avatar
To KRZZZ
You REALLY need to lay off whatever you are smoking. I challenge you to compare a VQ30s dyno graph with any honda motor you like, any one you can think of and look at the tq/hp numbers and the curve. Its not even close. i dont even think an LSX ***** would call the VQ30 tq-less.
Old Dec 20, 2011 | 11:07 AM
taz394's Avatar
all im saying is its cheaper to put a vq35 in and make more power
youre here doing all this internal work and then trying to make what 25x whp ? at the most
take this money into a stock VQ35 and see the results
but good luck ... i'll be waiting for dyno sheets and track times
and as far as i go i sprayed at 50 mph cause my car gets no traction even with 275 Drag radials and still ran a 12.9 @ 113
i sprayed in first gear in my other run and blew out a plug so i let off the pedal in 4th and still ran a 13.1 @ 102 coasting so i run 2 seconds faster then most these dek swaps after letting go as soon as i shift into 4th lol
i've beaten multiple vette's / gt500 / supra's etc
on a stock block/small shot
my motor is getting built now and coming back with a x3 shot of nitrous making 300+ easily all motor 93 octane
but again this thread is not about me
again to the OP sorry if you felt offended .. but i don't see your reason to do a motor swap for a de-k when there's cheaper ways of making more power WITHOUT touching and internals on a stock vq35 ...
do what you do ... i'll be waiting on dyno pulls
Old Dec 20, 2011 | 11:15 AM
taz394's Avatar
my dad fked your dad
$700 STOCK vq35 > $1000+ money in a dek (maybe more cause ya'll talking about cams and all that extra work)
Old Dec 20, 2011 | 11:21 AM
Crusher103's Avatar
has it run through your tiny brain not everybody wants a VQ35? Your wasting money on your land roaming titanic, go buy a Fox body or Camaro and you will run 9s with the money you put in your car.
Old Dec 20, 2011 | 11:35 AM
aackshun's Avatar
Bahahahaha, just wait, oh just wait
Who's to say he wont run 9's in his car with the money he put into the land-yacht?
And yeah, we'll say that when people admit that the DE-K isn't as cracked up as the dek riders (new phrase ) believe.
Now KRZZZ Likes the 3.0 for it's smooveness and lack of NVH characteristics, I have not noticed these things but it's his motivation for doing in then good, he's happy with it, whatever he's dealt with in the past he's dealt with, his decision, fine, good, great, not gonna argue with that.
It's like me when it comes to variable crap on my motors, I don't like variable ****, I will go out of my way to avoid anything variable.
Taz was just doing his usual E-juggernauting to scare off the dek riders, from the typical "OMG DEK W00TZ" comments, because there are those out there who believe with all of their might that DE-K > 3.5 in terms of N/A powah, when in the end, a DE-K is just an overweight K20 or B18
taz394's Avatar
i realize that now ... that some people rather just pick the harder more expensive way
i don't give a rats *** about the track lol ... i'd rather have my own car over a vette ...
im a roll racer
Old Dec 20, 2011 | 11:44 AM
Crusher103's Avatar
im a roll racer
i dunno but i dont see an NA VQ35 beating either of those cars.....
Old Dec 20, 2011 | 11:45 AM
aackshun's Avatar
reading > you.
Caught before you can make a ninja edit
Old Dec 20, 2011 | 11:47 AM
Crusher103's Avatar
reading > you.
No mistake there that is what i wanted to say, he just called himself a roll racer that can beat a few supras, vettes, and GT500. i hope you unplugged a couple of their coilpacks.....
Old Dec 20, 2011 | 11:48 AM
aackshun's Avatar
Since the booty pounder himself is having trouble reading.
Old Dec 20, 2011 | 11:51 AM
Crusher103's Avatar
nitrous is great but it aint that great. A 75 shot or whatever he ran will not make up for that kind of power disadvantage. We are talking about a roll racer here now....
Old Dec 20, 2011 | 11:52 AM
aackshun's Avatar
We will discuss later, have to go video diving, I'll PM you teh goodz when I/He finds it.
Anyways back on topic
7700rpm with Stock Bottom End??????
