Sponsored by:
Sponsored by: CARiD
Tomei Cams on Sale
Old Feb 1, 2012 | 08:53 PM
McSteve's Avatar
Tomei Cams on Sale
If you guys check out tomei website, the new MSRP for VQ35 cams is 880 bucks.
http://www.tomeiusa.com/recentmail.asp?mid=514
Lots of options to choose from. I debated the deluboz ones but then decided on Brian Crower Stage 2. This made me rethink and I'm gonna order the Tomei ones.
Old Feb 1, 2012 | 08:58 PM
Grand_hustle17's Avatar
Hold fast yo..... did I see 272 272 cams for under $500... I want the pro cams... I'm sure all of those fit just like the JWT would correct?..... I want some for my DEK...
Old Feb 1, 2012 | 09:01 PM
McSteve's Avatar
i'm pretty sure that's 440 for each side. cos the pom cams are 880
Old Feb 1, 2012 | 09:07 PM
ajcool2's Avatar
Thats a steal if you ask me
Old Feb 1, 2012 | 09:08 PM
ajcool2's Avatar
Here's a dyno of my boys G35 before and after longtube headers and tomei cams.
The car has nitrous but this was his best N/A runs. The shop just named it that way. His best on nitrous was 379/380
Old Feb 1, 2012 | 09:13 PM
What combo would I go with.. hmmm.... **** it 272 272 lol
Old Feb 1, 2012 | 09:19 PM
ajcool2's Avatar
That was done with the 260's.
Old Feb 1, 2012 | 09:25 PM
aackshun's Avatar
Old Feb 1, 2012 | 09:34 PM
McSteve's Avatar
you also get a couple options for lift to choose from. Could anyone explain to me how to calculate overlap?
I'm thinking the 272s with 11.3mm int 11mm exh lift.
Old Feb 1, 2012 | 09:35 PM
McSteve's Avatar
What IM was he using? Looks a little flat up top...
Old Feb 1, 2012 | 09:37 PM
Daaaamn.... I can only imagine.... *mind runs wild*
Originally Posted by aackshun
This lmao
Probebly their own lol.... the fair off a lil better up top IIRC
As good as that graph look ur boy technically lossed low end whp n TQ... he headers in itself should've gained all across the board but it didn't, the cams lossed low end but the headers brought it to equal but look at them top end power
Mmm, probebly won't go with the most aggressive lift
Old Feb 1, 2012 | 11:42 PM
ajcool2's Avatar
Stock with a 1/2 inch spacer and ported lower. He will be adding gears and an aluminum driveshaft next. My Z used to be neck and neck with his car and I'd pull away up top. Im sure he's going to walk me badddd now.
Old Feb 2, 2012 | 07:10 AM
SurraTT's Avatar
HR Swap Pioneer
nice find!
If they would of been that price during the summer......
VQ35HR
IN 272-11.30 142043
EX 272-11.00 142044
IN 280-11.30 142045
EX 280-11.00 142046
Old Feb 2, 2012 | 07:13 AM
SurraTT's Avatar
HR Swap Pioneer
http://www.ebay.com/itm/Tomei-Pro-Ca...item53e42bcc57
with the make a offer too.....
whyyyyyy did i see this!!!!!!!!!!??????
Old Feb 2, 2012 | 07:20 AM
Shift_Max's Avatar
So you can buy a set Darren.
Old Feb 2, 2012 | 07:21 AM
SurraTT's Avatar
HR Swap Pioneer
I might would if the prices was this good when the motor was out!
Old Feb 2, 2012 | 07:35 AM
Crusher103's Avatar
im iffy about it, i dont believe it, it is too good to be true. Aftermarket VQ cams are always in the thousands, now we are talking less than 500?
Old Feb 2, 2012 | 08:11 AM
DrunkieTheBear's Avatar
Turbo'd Saab
dude...
$440 for one side, you need both sides...so $880
Old Feb 2, 2012 | 08:21 AM
aackshun's Avatar
dude...
The drunken one delivers the anus <3'r from fail.
Old Feb 2, 2012 | 08:40 AM
nismology's Avatar
Either using a degree wheel or request a cam card from Tomei which they may or may not not make available to the public.
Old Feb 2, 2012 | 08:49 AM
Crusher103's Avatar
dude...
So its the normal price of tomei cams.....moving on.
Old Feb 2, 2012 | 09:16 AM
SurraTT's Avatar
HR Swap Pioneer
The MSRP went from 1180 to 880.
Link from first post.
Im wondering if any vendors are selling them under MSRP, as this is usually a advertised price. Like with Haltech's and such, you can get them new from vendors much cheaper then msrp
Old Feb 2, 2012 | 09:22 AM
MoncefA33's Avatar
McSteve are you gonna spin this motor to 8k+?
Old Feb 2, 2012 | 09:37 AM
Crusher103's Avatar
ive seen tomei cams brand new under 1G even on ebay so this doesnt surprise me.
Old Feb 2, 2012 | 09:43 AM
aackshun's Avatar
Yeah like 990 :
Old Feb 2, 2012 | 09:46 AM
i know i am
Old Feb 2, 2012 | 09:48 AM
SurraTT's Avatar
HR Swap Pioneer
ya, so now the msrp is $300 lower, maybe the "real" price will come down some also.
Old Feb 2, 2012 | 09:52 AM
this is good enough lol
Old Feb 2, 2012 | 10:15 AM
ranmas2004's Avatar
DAM...272!!! WOW! Wont that idle really nasty? Low end might be total garbage after that? I think with anything over 11mm lift you will need new valve springs too. I was considering the JWT S1 cams they are like 260 10.87mm. They actually did a cam test on a 350z in modified magazine. They dyno tested Stock cams 238(In)/240(Ex)/9.57mm, Tomei 264/10.5mm, JWT S1 cams, and the Nismo Rtune cams 262/10.82mm. Actually from the dynos the JWT S1 cam gained 19hp and 13ft-lbs. peak over the stock cams. The JWT S1 cams did not lose ANY low end torque and had a nice gain up top too! Actually low end torque increased! The JWT S1 cams made the flattest torque curve. What I found really nice was that the JWT cams gained torque and horsepower through the ENTIRE rpm band and did not lose any power over stock anywhere.
Here's the article if anyone want to check it out:
http://www.modified.com/tech/modp-10.../photo_18.html
Only thing negative about cams is the labor for install....I heard it was somewhere like $1000-$1200 + cost of the cams. BUT I think with the Haltech being able to control some cam timing you would probably pick up even more low and mid range torque.....hmm......
EDIT: Figured I'd post the dyno chart of the cam test done as well.....
STOCK = Green (hp) Blue (Tq)
NISMO = Purple
Tomei = Red
JWT = Yellow
Old Feb 2, 2012 | 10:48 AM
95naSTA's Avatar
nice find!
x2 I ripped mine out to re-seal the timing cover.. I didn't want to spend a G or more on cams at the time.
Old Feb 2, 2012 | 11:42 AM
taz394's Avatar
-_- just bought JWT C2's 2 weeks ago
Old Feb 2, 2012 | 11:59 AM
Welp... based on that graph.... JWT it is..... TQ is just as important as whp, especially seeing as though I have a Tq-less DEK lol
Old Feb 2, 2012 | 12:05 PM
SurraTT's Avatar
HR Swap Pioneer
Why? The S1 is the smallest cam JWT has so low end isent hurt that bad. the cams in that test are just the ones after stock.
lol now im wanting to put cams in already!
With the IVT and EVT, possibly i could get an aggressive cam, and keep some low end too. Gonna have to wait tho, stock FWD cams for me ... for now
Old Feb 2, 2012 | 12:09 PM
SurraTT's Avatar
HR Swap Pioneer
http://www.jimwolftechnology.com/wol...INCL_REVUP.pdf
Old Feb 2, 2012 | 01:03 PM
a crazy cam lope is nothing to me if the car aint making power... the S1's are plenty enough for a car that would make no more than 300whp.... dont need anything else for a daily
Old Feb 2, 2012 | 01:06 PM
i dont think this post served the purpose of the reason why its posted cause idk wtf im looking at lmao!!!.... the different cams???
Old Feb 2, 2012 | 01:07 PM
McSteve's Avatar
http://my350z.com/forum/forced-induc...ts-are-in.html
pretty interesting read. comparison between brian crower stage 2 and 3 on a turbo 350z.
I made them an offer on ebay for 799 and they accepted.
Old Feb 2, 2012 | 01:38 PM
SurraTT's Avatar
HR Swap Pioneer
niceeee, so 834 shipped. for VQ35 cams brand new. good price imo. Sure sounds a lot better then $1100 shipped... haha
Old Feb 3, 2012 | 01:34 PM
McSteve's Avatar
one of the most popular 350z cams are the gtmotorsports cams.
http://www.gtmotorsports.com/product...cat=264&page=1
they have a greater intake duration than the exhaust.
what do you guys think about mating the tomei 272 intakes with 264 exhaust cams?
Old Feb 3, 2012 | 02:46 PM
ajcool2's Avatar
Ive used this a few times in the past to compare JWT's to other cams out there specifically our BC2's.
