Sponsored by:
Sponsored by: CARiD
VQ35HR cams w/DE VTC cam gears?
Old May 29, 2012 | 10:29 AM
Maximeltman's Avatar
Sorrry if its been asked b4, but I searched and cant find anything. Anyone know if and engine with vq35HR cams can run with the vq35DE VTC cam gears?And if so, Would it need an HR ecu, or will a DE ecu work also? I think that the DE and HR cams are opposite as far as timing goes, the HR is like the vq30de.
Old May 29, 2012 | 11:12 AM
SurraTT's Avatar
HR Swap Pioneer
The older intake cam gears have 40 degrees of travel, the HR style have 50. So if you are running 3.5 timing get the HR style. IMO
I beleive they are similar, but with the IVT solenoid in a different location there might be some cam gear differences.
Old May 29, 2012 | 12:02 PM
So in short, If I used HR style cam gears, then I would need different main caps/timing covers due to the solenoids?
Old May 29, 2012 | 12:11 PM
Crusher103's Avatar
wait, your using HR cams in a car with 3.5 timing?
Old May 29, 2012 | 12:23 PM
SurraTT's Avatar
HR Swap Pioneer
Well if your using HR cams with 3.5 timing your bigger issue is the cam sensor.
If so thats pretty much a 09 swap, using HR heads would need a 09 lower, then a 09 upper intake. and also would need a 09 timing cover, or a 07 altima if no EVT wanted.
Old May 29, 2012 | 12:28 PM
Crusher103's Avatar
Yea, unless he is using 3.0 timing.....i dont think this will work.
Old May 29, 2012 | 12:33 PM
Crusher103's Avatar
Unless what he is asking is there a difference between where the CPS sensor reads. The answer is no with 3.0 timing because the CPS reads off the cam gear not the end of the camshaft.
Do you have pics of your setup? Because this question is making me think what you did is put the cam spacers on then reused all the VQ35 timing stuff which is wrong.
Old May 29, 2012 | 02:55 PM
Yes, that's how I received the swap-ready motor. Freight company dropped my engine. I did a leakdown and wasn't satisfied with high fluctuation in the test results, so I started to tear it apart, and it had the 3.5 secondary cam gears, and 3.0 main gears/timing chain which I was told is probably fine, just not as precise as the 3.0 secondaries w/spacers. I need to get some 3.0 secondaries now. That's if I just reuse the 3.0 ECU, though. It's a 99 ECU, and I read about mad codes with it, so I either want a 95-97 5speed ecu, or I want to know if I can just go with VTC and a 6gen ECU. I have HR cams and I already have a 3.5 timing cover and now I find out I have secondary gears and chains, so I'm contemplating getting DE or HR main cam gears and using a 3.5 ecu so it can have VTC also.
It's probably a bad idea. Just asking about what you guys think.
Old Jun 4, 2012 | 03:45 PM
What you think I will need to run in a 99? I can get DE intake gears pretty cheap, no exhaust gears tho.
I just wondering, about how much extra HP/TQ would I be missing without the VTC on intake and exhaust? (BALLPARK)
I read in your thread about how with the variable exhaust timing really had graet gains over without variable exhaust timing.
I know that simply keeping the VTC variable out the whole equation and just use 3.0 timing with a tune is a bit easier, but as they say when in rome..
user 11122324
42
Jul 18, 2022 03:35 PM
knight_yyz
Nov 1, 2015 01:34 PM
