DEK/VQ35 Hybrid Setup Qs
Okay so this week I will be performing the following.
My DEK ported/polished/valvejobbed heads on top of a mildly built VQ35 block, using the following bits:
Anything else I should look out for that are specific to this type of build?
Approx compression ratio?
What kind of AFR/timing #s should be shooting for?
The other typical 3.5 swap will be taken care of, but if anyone else has any tips I will be glad to listen to them.
- S1 knockoff cams/HR valvetrain
- ARP headstuds (VQ35DE)
- 3.0 timing/ECU
- SSIM portmatched, NWP spacers, PFTB, 82mm MAF (for now)
Question:
I'm not able to fit the VQ35 LIM/UIM on this setup, because the plenum is hitting the coilpacks. It barely clears the rear valve cover (5th gen).
What valve cover should I be using so I can put my SSIM on there?
James92SE
142
Jan 2, 2024 09:23 AM
Apr 16, 2020 05:15 AM
CAN-Toronto FS: Emanage Ultimate and plug/play Harness
knight_yyz
Nov 6, 2015 02:34 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
