Sponsored by:
Sponsored by: CARiD
4th gen 95 ecu/harness tps with pathfinder throttle body
Old Apr 1, 2014 | 09:58 AM
TurboA32's Avatar
I have a question about the 95 maxima with one harness on the tps sensor and want to do a pathfinder throttle body swap what do they do about the tps sensor on the pathfinder throttle body having two harnesses on it. Do you guys just use one part of the pathfinder throttle body tps sensor or do you guys swap the one harness sensor on the pathfinder throttle body? I just recently found out that some 95 maxima's come with a one harness tps sensor as the other maxima's come with two harnesses on the tps sensor.
Here's a one harness sensor
http://www.autozone.com/autozone/par..._2001%2C990258
Old Apr 1, 2014 | 05:55 PM
schmellyfart's Avatar
One of the plugs on the 'two plug' tps is just to tell the ECU if you at WOT or no throttle, the other is for the actual throttle position.
That being said I used my 4th gen tps (two plug) on my PFTB.
You have two options, either swap out the PF TPS for your 'single plug' TPS, or just plug your only TPS plug onto one of the two receptacles on the PF TPS, as it should only fit one of them.
MAXSE5SPD
Sep 17, 2022 04:00 AM
AcuraLegend
Sep 22, 2015 04:22 PM
Lowered_a33
Sep 1, 2015 07:49 PM
Maximeltman
Aug 31, 2015 01:01 PM
Samedi
Aug 13, 2015 04:05 PM
