Installation Question
Old Dec 13, 2000 | 04:31 PM
Max79's Avatar
Is it hard to install an aftermarket sound system in a 95 SE with the Bose system? Will I be able to use any of the existing Bose wiring? Where is the hole in the firewall? Will it accept a 2 gauge wire? How do you dismantle the dash to install the radio? Do the grills pop off the front doors? Thanks for any info.
Old Dec 13, 2000 | 05:42 PM
Nathan's Avatar
Hey Max79, since your a Newbie I thought I should help you out. Anyways, if you need help removing the dash check out my website to the left and look under shoptalk. For the firewall, on my '99 Maxima it's around 8 inches above the gas pedal. If you can't find it, look under the hood to see if you can find it. Good luck!
PH98I30
Jan 9, 2025 08:08 AM
JRod28
Dec 29, 2023 09:56 PM
mikekay
Aug 10, 2015 12:52 PM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
