Why doesnt my power antenna work
Old Aug 19, 2002 | 07:34 PM
CASS98SE's Avatar
After installing my cd player, (pioneer deh 6400) my power antenna no longer goes up. Was there something extra i needed to buy to make this work, or did i just forget a wire?
Old Aug 19, 2002 | 09:52 PM
Gates's Avatar
Re: Why doesnt my power antenna work
My memory is kind of hazy but I'm pretty sure that all you need to do is hook the power antenna wire from your wire harness with the remote wire. Pioneer doesn't have a seperate power antenna wire so that means that even when you play a CD your antenna will go up....
Old Aug 19, 2002 | 09:57 PM
Coldboot-SE's Avatar
Pwr antenna
CASS98SE,
Having owned a lot of Pioneer products over the years , I would say that if you check out your connection pioneer doesn't have a antenna lead, but a remote turn on that many use to activate the antenna.
I have a Pioneer 8600 and use a branch off my "remote turn on" through a switch to power my attenna, otherwise the antenna would go up each time I turn on the radio.
I hope this helps
DC
MikesChevelle
Nov 23, 2024 11:17 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
