ok.. CHEEZERS in the audio shizzzzz
Old Sep 22, 2002 | 07:32 PM
ChrisCheezer's Avatar
ok i just put my kenwood head unit in ... its DOPE!!!! sounds amazing.. only one thing.
Im getting engine nosie though the speekers.. i have tryed grounding the head unit and all the other **** to "better ground" but nothing works.. then i relized that it does the same thing (light buzzing noise) when then ground wires are not even on.. ground.. WTF? how can the head work if there is no ground ...
Q-how do i ground my head unit and addapter i bought..
Old Sep 22, 2002 | 08:52 PM
mb1's Avatar
mb1
Re: ok.. CHEEZERS in the audio shizzzzz
if you scew you head to the factory brackets, then it's grounding through those I believe.
Old Sep 23, 2002 | 08:52 AM
well im doing somthing wrong...
because i have all my ground wires attached to one. and its just hanging.. not attached to anything!.. and im still getting the same sound.... how the F is this happening? i have no ground... it should not work at all... but its working, just with some bad engine nosie that goes away if you crank it...
Bose kicks a$$! lol...........
Old Sep 23, 2002 | 02:53 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Re: well im doing somthing wrong...
Your radio IS still grounded, it is called a "floating ground" through the antenna. Your antenna is grounded therefore so is your radio. Also the noise does not go away when you turn it up, it is just covered by the loudness.
--Don
Old Sep 23, 2002 | 09:23 PM
Tony Fernandes's Avatar
Re: Re: well im doing somthing wrong...
Try grounding the HU to different locations. The more of a direct metal contact-to-chasis the better. Are you using amps? Is the grounding problem coming from them and not the HU?
Tony
Old Sep 23, 2002 | 09:38 PM
when i turn it up...
when i have it loud it is still there... getting coverd up thou, you cant really hear it unless you are sitting there waiting for the music to quiet down for a sec, the speakers have nothing to do with it right?... one person told me that the bose speakers are my problem and that i should buy a pair from them... i was like "fffff uuuuu" bose kicks ***...
bose for life... or untill i can afford a real system..LOLOLOL
Old Sep 25, 2002 | 08:25 PM
SIRI_SE's Avatar
I can tell you it is DEFINETLY not your Bose speakers, most likely it is a grounding problem, or could be you need a noise filter. For grounding problems try scraping the area you are mounting your ground screw with a metal brush or a screwdriver, make sure its clean then apply wire. Good luck.
Robert Schneeweis
Jan 11, 2017 06:47 PM
Fbana41
Aug 29, 2016 12:18 PM
Excalibur23
Oct 13, 2015 04:33 PM
BrandonCause
Sep 20, 2015 10:20 PM
popdedop
Sep 11, 2015 11:17 AM
