Deck install help, specifically RADIO hookup
Old Oct 5, 2002 | 02:01 PM
commander316's Avatar
how do i hookup the radio to my new stereo.
im gettin an aiwa deck and i want to know what i have to do special before i start takin apart my car
i read somewhere there is something special u have to do for the radio to work
is it cuz of the motorized antenna
thanx a lot
ur help is very greatly appreciated
Old Oct 5, 2002 | 02:12 PM
pjalst
Re: Deck install help, specifically RADIO hookup
thanx a lot
If you have a Bose system, you'll have headaches. If you have a non bose radio there's nothing special to do. You don't have to take apart the whole dash to take out the factory radio, Just the center console. Start be prying up the plastic around the shifter and work your way up. I used a radio wiring harness That I got from www.crutchfield.com to connect the wires. The harness makes the job alot eisier and if you decide to return it to the stock radio, all you have to do is plug it back in. I suggest you do more research before you take on this task. I found everthing I needed on the internet to install my radio and amps.
pktaske
May 6, 2016 07:49 AM
Pnjboyzz
Sep 4, 2015 09:04 AM
pktaske
Sep 4, 2015 08:40 AM
