Richard Clark testing Adire Audio Brahma 12
Check the link:
http://www.carsound.com/cgi-bin/ubbc...?ubb=get_topic;f=1;t=019193
I'll be driving down to N.C. on Monday. It was only planned in the past week. What a blast this should be.
Re: Richard Clark testing Adire Audio Brahma 12
JMAX,
This has nothing to do with this post (seeing how I am in southern Louisiana and all), but I wanted to ask you a couple questions if possible. First, I see you have "Tons'o'damping". Well, did you put anything ON your rear deck? If so, did you put anything on the bottom side, or the top side of the rear deck,,,OR both?? And what about those 2 lil bars that run across the trunk, did you do anything with them? Just a few simple questions, hope you don't mind sharing some info....
Thanks man,,,,,DMAN
Thanks man,,,,,DMAN
Re: Re: Richard Clark testing Adire Audio Brahma 12
Originally posted by DMAN11
JMAX,
Thanks man,,,,,DMAN
JMAX,
Thanks man,,,,,DMAN
As for dampening most of what I have installed is in the doors. The doors open and close like a cadi. I've got some that I am going to remove sometime in the next 6 months and plan to replace with "different" materials. And the rest of the cor should also be finally layered or relayered in these other materials at that time. I need warm weather to do it. I don't have a garage large enough to open my doors. And transporting all the materials and tools needed to apply them to someplace where I could do the work would be a chore in itself.
I don't want to misquote so I will cut and paste instead.
http://www.carsound.com/ubb/ultimate...?ubb=get_topic;f=1;t=019193;p=8
RC's post:
"guys----i finally got in touch with Dan last night at 9:00--------i wanted to review my results and hear his comments before i posted my findings--------not that it would change anything but i always feel it is a fair thing to do rather than put someone on trial without hearing their comments---------and i realize that a test like this tends to create somewhat of a "trail" atmosphere-----i was especially concerned since it was clear to me that the conditions of the test didn't allow the Brahma to perform at its best------Dan seems to be both polite and knowledgable and i enjoyed the conversation------MY OBSERVATIONS------as i have stated already i believe that with an amp of less than about a killowatt that the brahma might output a little more sound (ie appear to be a little more efficient)-------but based on upper frequency distress tests (not affected so much by box size or car rattles)------the JL is clearly capable of more linear (read lower distortion) maximum movement------NOW before everyone jumps in and starts to spout DUMAX mumbers let me clarify a few things that i had not previously considered about DUMAX testing-------it is a remarkable machine and as a method of demonstrating MOTOR and SUSPENSION linearity it has no equal---------but the dumax measures the movement under static conditions and not when they are moving at a high rate of speed-----this means that any part of the suspension, spider, coil, or tinsel leads that causes secondary resonances, buzzing, rattles, pops or whatever you want to call them will not show up in the DUMAX linearity tests-----at least not the tests that plot displacement vs applied force-------based on the audible distortion threshold limits of the two speakers the JL exhibited inaudible distortion power handling at levels that were at or near the limits of the brahma when it was at or near its distress limits-----(i will have brain post the charts later in this thread---just remember to ignore the audible distortion curve on the brahma due to the distortions caused by the car))------it is a logical conclusion that the JL would easliy outperform the brahma at any frequency/power level that produces very high excursions-------REMEMBER that this is considering audible distortion and NOT raw SPL------the brahma is a very good speaker but the JL is simply incredible and thats all there is to it-------anyone want to come by and hear the JL being driven to ridiculous power levels and still remain free of distortion is certainly welcome--------the suspension in the 13w7 is amazing and at the present time unequalled by anything i have yet to measure or hear-------in car racing there is a saying "engines make you go fast but its tires that win races"-------i have a saying about speakers-------"magnets and voicecoils make speakers powerful but its suspensions that make them sound good".................RC
[ October 23, 2002, 03:09 PM: Message edited by: Richard Clark ]
we consider "physical stress limits" to be the point where any experienced speaker engineer, technician, or sensible audio person would consider that the speaker "has reached its limits" and would use good judgement and turn things down a little-------things like snapping, popping, rattling or just plain sounding like its gonna "blow"---------this threshold usually comes on very steep and has a clear threshold----------audible distortion limits is just what it sounds like-----we listen to the burst and when we just begin to hear the pure tone start to distort we call that the "audible distortion thershold"------and believe it or not with a little practice it is very repeatable from person to person--------if you have the ALMA CD and a really big amp give it a try-----or------if you ever visit i will demo it to you.........RC"
Basically he repeated his statement that he has never tested a better sounding speaker than the W7. But did not way anything bad about the Brahma, especially considering it's price point. Overall I was very impressed by how the Brahma did. Especially considering that it was installed by a normal guy, not a pro.
RC's post:
Originally posted by nismo240sx
keep in mind that he was hitting the brahma with 32,000 watts! unfortunately, he never got to test the w7 at that much power...he only got to test it on 20,000 watts.
eric
eric
tarun900
19
Dec 20, 2021 06:57 PM
knight_yyz
Nov 1, 2015 01:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
