What are the pros and cons of adding a second battery?
Old Oct 18, 2002 | 08:24 PM
eaglclon's Avatar
Should I or should I not?
Old Oct 19, 2002 | 01:33 AM
TL@altimas.net's Avatar
Pro- More off-engine listening time
Con- More strain on alternator, especially if you don't use a battery isolator..
Old Oct 19, 2002 | 08:47 AM
eaglclon's Avatar
what's a battery isolator
Old Oct 19, 2002 | 02:30 PM
basically a solenoid that disconnects the extra battery, so that your alternator isn't trying to recharge 2 batteries at once..
Old Oct 19, 2002 | 10:03 PM
nadir_s's Avatar
vicodin ... gift of life
why can't we have 2 alternators
Old Oct 20, 2002 | 12:04 AM
You can.. if you have room for another, and most likely another idler.. or you can replace another accessory (A/C, PS)
Old Oct 20, 2002 | 06:50 PM
friendhasmax's Avatar
huh?
bro ....the alternator is supposed to charge both batteries simultaneously...what a battery isolator does is this: it keeps both batteries seperated from each other. so that when the car is off, a battery that has been drained more than the other wont pull current from the battery that has more charge. isolator is like a one way valve. it connects both batteries to the alternator so as to charge both at the same time, and as a valve (using diodes) to keep the batteries seperate from each other.
Old Oct 20, 2002 | 07:33 PM
lol, according to this we're both off base..
http://www.soundillusions.net/module...owpage&pid=113
Old Oct 20, 2002 | 07:39 PM
i was on point with that one
i didnt say it clearly though, i'll give u that....the isolator seperates the 2 batteries from each other meaning one can be drained without affecting the other, and both are charged simultaneously
Old Oct 20, 2002 | 07:47 PM
max'n out's Avatar
Why exactly do you think you need 2 batterys?
bigfrank
Oct 1, 2015 12:51 PM
jaydot901
Sep 29, 2015 01:18 PM
Redfox
Sep 28, 2015 10:41 AM
Socalstillen
Sep 26, 2015 12:01 PM
