what gauge speaker wire for 150 watts?
i am wiring my speakers and i need to figure out what gauge speaker wire to use. each component will be getting 150 watts, so should i use 13ga., or 11ga.? the wire im using is RF Riot Gamma Geometry any help is appreciated.
(P.S.- 11 ga is 1.80/ft and 13 ga. is 1.25/ft so im prayin its 13 ga.
Originally posted by maximadave
for speaker wire, 16 gauge is more than enough. Use 8 guage on your amp.
Power wire, well... depeds on if you run other amps as well!
if that is your only amp and your not gonna upgrade, 8 guage power 16 speaker
if you have more then one amp 4 to 0 guage power and then 16 speaker or 12 would be fine, the voltage drop on 150wrms on a speaker wire is probably not even audible
BTW no need to pay for RF riot wire
www.knukonceptz.com is like 1/4th the price and wire is wire in 99.9% of the install cases i've seen it dont matter
How long are the speaker wires going to be??? The longer, the thicker. If you're only going a couple feet(such as mounting the amp to the box) then 16ga should be fine. If you're going over 5ft., I'd suggest 12-13ga minimum.
im running 10 gauge to horns, and a (probably) a pair *per side* of adire audio koda 6.5's in ported kicks...only getting about 50-90 watts each, but i dont like running tiny wire--it matches better at the amp, so i pay a lil more
ill probably run 10 or 8 for 3000 watts to my brahmas
eric
eric
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
