Is this possible?
Old Dec 18, 2002 | 07:45 AM
MoDiddy's Avatar
Is this possible?
When i get my sub installed i want to have the bass from the rear speakers removed and have music comming out...i have a bose system..is this possible?
thanks
Old Dec 19, 2002 | 12:51 AM
TL@altimas.net's Avatar
yes, use a bass-blocker.. Crutchfield or any stereo shop should have them..
Old Dec 19, 2002 | 04:29 PM
MoDiddy's Avatar
Old Dec 21, 2002 | 09:06 PM
studman's Avatar
Last time I checked, the BOSE system had a sub mounted in the trunk. When I did my install in my '02, I just unplugged the connector going to the sub. Then all the lows were gone. No need to buy bass-blockers, etc. BOSE has the crossover located in the amp, not the HU, so you only need to bypass the sub in order to remove the bass. Now if you want to remove the mid-ranges, you may need some "bass-blockers" that are set for higher frequencies.
