Remote turn-on wire
Remote turn-on wire
I just installed Rockford Fanatic Q, HPC2206, and 10" Punch Z speakers in my '97 Max. I am keeping the factory HU (non-Bose) for now. I wired the amp turn-on to the blue wire (hot when car is in AC and Run modes) on my HU. I would like to know if there is a way to wire the amp so that it is only on when the HU is on? If there is, which wire is it?
Also, I noticed that when the amp is powered on and I turn on my headlights, the RPMs drop slightly? How do I fix this?
Re: Remote turn-on wire
Re: Re: Re: Remote turn-on wire
Thanks for the help...I will give it a try.
Where is best source for the +12v constant? Can I use the power wire in my HU harness?
Re: Re: Re: Re: Remote turn-on wire
Originally posted by phenryiv1
12v constant for what purpose? To power your amp? More info and I am sure that we can help you.
Currently my amp's turn on wire is connected to the blue power wire in my HU (stock non-bose) harness (that wire is hot only when car is in AC or Run mode). When I add a 4-pin relay to the mix is that blue power wire the best source for +12v power? Ideally I would like my amp only to be powered when the HU is on. I also am planning on adding a toggle switch to the turn on wire so I can turn the amp off but still listen to music.
Re: Re: Re: Re: Re: Remote turn-on wire
Re: Re: Re: Re: Re: Re: Remote turn-on wire
So are you using this to POWER-ON your amp, or to provide POWER TO your amp? I know that stinger used to make (and may still make) a unit for about $20 that would send a turn-on signal to your amp. Uou wired it inline with speaker-level signal, and when the unit sensed speaker signal, it would send a 12v turn-on signal to amps to power them up. Is this what you are looking for?
Power is run from the + terminal on the battery, the line from the HU is to turn the amp on. The stinger product might be what I need...I will check on it.
Re: Re: Re: Re: Re: Re: Re: Remote turn-on wire
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
