FM modulator install question
Old Feb 16, 2003 | 07:46 PM
enticiveblkmax's Avatar
i grabbed this quote re: nissan's diversity antenna, from the sirius radio thread in the group buy forum and would like some clarification on where this jack studman is refering to. i tried feeling for it and came up with nothing. has anyone else used this method? thanks.
Originally posted by studman
Basically speaking, you don't need the FM antenna adapters for the 4th Gen Max's. Inside the trunk where the jack is stored is the factory antenna. Feel the cable coming off of it and you'll find a connector 3-6" down the cable. Unplug the connector and insert the FM modulator there. It's a standard antenna connector, and doesn't require $20 in adapters ($10 each) nor removal of the HU.
http://forums.maxima.org/showthread....5&pagenumber=5
Old Feb 16, 2003 | 10:15 PM
studman's Avatar
Some people have said that the jack isn't there. On my 98, it was there. Open the trunk. Remove the factory jack. Find the base of the antenna with your hand. Follow the cable coming out of it. About 3-12" down (varies between models) there should be a connector that is a standard male antenna to female antenna. It was on my 93 GXE as well. If you can't find it, then Nissan must've messed up or something during those years, because it was there on my 93 GXE and there on my 98 GLE as well. That's how I tapped in my 12 disc CD changer that I had at the time.
PH98I30
Jan 9, 2025 08:08 AM
JRod28
Dec 29, 2023 09:56 PM
mikekay
Aug 10, 2015 12:52 PM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
