PLEASE HELP ME jbl bp1200.1 and hx2 question
Old Feb 25, 2003 | 09:17 AM
alexg240's Avatar
I have two 12 inch rockford hx2's and I just ordered an jbl bp 1200.1 amp The amp is advertised as a mono amp but there are 4 terminals for speakers on the amp. If I had the voice coils on each hx2 wired in parallel two make two dirvers wired at 2 ohms each sub a total load of 1 ohm how would I hook them up to the amp? the amp is 1 ohm stable
I thought a mono amp would just have 2 speaker terminals not 4
Old Feb 25, 2003 | 01:44 PM
phenryiv1's Avatar
Mod her. Ate her.
Re: PLEASE HELP ME jbl bp1200.1 and hx2 question
Wait until you get the amp and check the manual. I imagine that the 2 sets of outputs are still mono, they just make it easier to use heavy gauge wire w/o jamming it in a small terminal. YOu could wire each sub in series (8 ohms per sub) and then wire the pair in parallel (for a total imp of 4 ohms). Basically, you needed to buy 2 SVC subs...
Old Feb 25, 2003 | 03:35 PM
Supa Lao's Avatar
Just wired the subs up in parallel and then one sub goes to one + and -, and the other sub goes to the other + and -. That will give you, your 1 ohm load.
Old Feb 26, 2003 | 05:21 AM
MaxSE03's Avatar
I checked the Owners manual on the JBL site and it doesn't give any detailed instructions. I have a Kenwood 810d mono amp with 4 terminals. The manual for it gives detailed instructions and diagrams. Here is a link to it's manual: KAC-X810d It should give you a good idea!
Craig
Old Feb 26, 2003 | 07:32 AM
phenryiv1's Avatar
Mod her. Ate her.
Is that amp designed to run a nominal 1 ohm load?
Old Feb 26, 2003 | 06:42 PM
Supa Lao's Avatar
Amp says it's 1200W @ 2 ohm, but @ 1 ohm, it doesn't gain anymore power.
Old Feb 27, 2003 | 08:33 AM
phenryiv1's Avatar
Mod her. Ate her.
But is it even designed to run that low? Hello, fire department, if it is not!
Old Feb 27, 2003 | 09:16 AM
Supa Lao's Avatar
Yes, you can run it at 1 ohm. It is stable down to 1 ohm
Old Feb 27, 2003 | 03:36 PM
kingrukus's Avatar
no more maxima...
The amp puts out the same power at 2 and 1 ohm. The 2 sets of terminals are there to allow for a less confused, easier hookup.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
