ports
Old Mar 19, 2003 | 06:37 PM
AscendantMax's Avatar
ports
i'm thinking about converting my sealed box into a ported one. my question is, does it matter where you place the port? ( on top, side, back, front of the box) thanks
Old Mar 20, 2003 | 08:07 PM
bubblersound2's Avatar
port sub box
The ports should be on the same surface as the speakers. Box should be against rear seat, speakers facing rear of car.
Old Mar 20, 2003 | 10:52 PM
jmax
Where they are located on the box does not matter so long as they remain unobstructed. Good luck getting your sealed box to sound good ported.
Old Mar 21, 2003 | 02:09 PM
yea hopefully it won't be crappy. my box has the right internal air volume to be ported, specified by my sub's manufacturer, so i figure what the heck i'd give it a try. thanks for the input
Old Mar 22, 2003 | 01:16 AM
jmax
You need to subtract from the sealed box volume the displacement volume of the ports.
Old Mar 27, 2003 | 02:28 AM
lunchbox's Avatar
also when you port the box it's a good idea to get a subsonic filter. Ported might be a little louder but it won't sound as good. I'm sealing my ports.
Kevin
Old Mar 27, 2003 | 05:58 AM
jmax
A well designed and built ported box can sound as good as sealed. That's the key, building it right. Most ported boxes are built strictly for spl and not for sq.
Old Mar 28, 2003 | 06:47 PM
well i never did made my box ported. i went over to my friend's house and tried it on his setup. it wasn't being used and was sitting in the garage. it sounded ok but not as defined as a sealed box. i guess i'm going to leave my box as it is since i'm looking for clear bass response. I think it's time to upgrade my tens to something better. thanks for all the input.
Old Mar 29, 2003 | 12:11 PM
lunchbox's Avatar
I sealed up my ports the other day. Its much louder and tighter. The Tempest likes sealed much better.
Kevin.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
JonBlz
Oct 5, 2015 06:02 PM
vrajesh123
Sep 22, 2015 04:20 AM
Car Addict
Audio/Video/Electronics
Aug 27, 2015 09:01 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
