Infinity Basslink
Old Mar 22, 2003 | 06:02 PM
jmh8's Avatar
Infinity Basslink
Hey guys,
I'm looking to buy one, but want some feedback from those who either have one or have heard it in a Max. I would really appreciate some feedback as I am lookin at one on e-bay. Thanks!
Old Mar 22, 2003 | 06:30 PM
Y2KSESteve's Avatar
Enough bass for me, plus I have a ton of trunk space left over.
Old Mar 22, 2003 | 06:39 PM
jmh8's Avatar
Did you leave the Bose sub in or take it out to use the hole as a port? Is the bass clean and crisp? What do you have the gain and levels set at? Thanks!
Old Mar 22, 2003 | 06:54 PM
HitManSE's Avatar
I dont belive he has BOSE. It doesnt sound too bad at all, but it hits the lows better then it does the rest of the notes. Its frequecy response inst really too wide. 25-150Hz if I remember my stats correct. For its size its awesome but u cant really bump fast hitting music like rock, metallica, AC/DC, ect... and have have it stay accurate the whole time. But it does sound exceptionally good, especially considering its size. I was also considering getting 1 just to have bass til I get a bigger and better setup.
Old Mar 22, 2003 | 07:12 PM
AscendantMax's Avatar
yep that passive radiator really backs up the main driver. now only if it too was an active 10" driver...
Old Mar 22, 2003 | 08:18 PM
XXXL Cracker's Avatar
Pretty happy with the sound...sounds good. Enhances current set up..
D
Old Mar 22, 2003 | 08:22 PM
jmh8's Avatar
So did you leave your Bose sub in? I am debating whether or not to take it out and see if sound is better using the hole as a port.
Old Mar 22, 2003 | 08:45 PM
I originally ws running it with the double din HU
I now installed an aftermarket HU with a peripheral connector for the stock speakers. My sub is running right off the hu now.
Dave
Old Mar 22, 2003 | 08:49 PM
kingrukus's Avatar
no more maxima...
Isn't the basslink just an amplified subwoofer? If so, you would not want it hitting beyond 80hz anyways....anything higher is usually the mid-bass's job.
Old Mar 22, 2003 | 09:12 PM
HitManSE's Avatar
Not necesarrily, U want the subs to play the low note very well obviously so if the sub u get has a short freq range like that, its usually sloppy or in other word farts. The basslink doesnt fart but isnt too accurate with fast paced music. U want a sub thats got a freq range thats atleast from 20Hz-400Hz. This is just my .02 in no way am I a sterio guru or nothin.
Old Mar 23, 2003 | 01:33 AM
Speebs's Avatar
I aim to misbehave.
I have a Basslink... it's decent. It took me a while to get my settings right, but once I found them I was very satisfied. It takes up virtually no space in the trunk and gives me enough bass to keep me happy. I would recommend removing the BOSE sub to port the trunk. I do not have BOSE in my car, and I found that when I had the armrest closed, the bass was relatively muffled. I used to just open the armrest/ski hole, but then I ported my rear deck and put a speaker grille on it. Muuuuuuuuuuuch better
There are a couple of pictures on my homepage.
Old Mar 23, 2003 | 05:31 AM
jmh8's Avatar
THanks for feedback. One question. The one on e-bay does not come with the remote. Do you know where I can get one? Is it necessary to have? Also, I am going to be getting this installed at Circuit City. Can you tell me all of the wiring/kit I will need so I can buy it ahead of time? I'm sure C.C will charge me an arm and a leg for the cables. WHere can I purchase the Cables cheap?
Old Mar 23, 2003 | 07:33 AM
kingrukus's Avatar
no more maxima...
I highly doubt you would want a sub to play above 80hz...never mind 400hz....in most systems, frequencies are cutoff well below 100hz to the sub bass. From 70-100 up, the midbass takes over.
QUOTE]Originally posted by HitManSE
[/QUOTE]
Old Mar 23, 2003 | 08:07 AM
mzmtg's Avatar
Minister of Silly Walks
No you don't. 80Hz, maybe 100 tops.
Old Mar 23, 2003 | 10:39 AM
maximamaybe's Avatar
Originally posted by mzmtg
It is the soldier not the reporter who has given us freedom of the press.
It is the soldier not the poet who has given us freedom of speech.
It is the soldier not the campus organizer who has given us the right to protest.
It is the soldier not the lawyer who has given us the right to a fair trial.
It is the soldier who salutes the flag, who serves under the flag, and whose coffin is draped by the flag who gives the protester the right to burn the flag.
Let us not forget the men who have died to give us the freedoms we now take for granted.
Much props on your signature. I am glad that some poeple realize that you should support your govenment and it's soldiers. Some people do not realize how life could have been it it werent for the brave soldiers willing to risk their life for us.
Old Mar 23, 2003 | 10:58 AM
Speebs's Avatar
I aim to misbehave.
Basslink stuff is cheapest on Ebay- the remote ***** are around $15. I find the **** VERY useful, because different depending on how a CD is mastered, it may have different levels. A lot of the time I need to turn the bass up or down, and I don't need to go into the trunk to do it. I would recommend getting the remote, but it's not absolutely necessary.
I just got some 19' Stinger Hyper Series RCA interconnects because they were on sale and very cheap, and an 8 gauge Stinger power kit. Works great for me.. no interference or anything. Cables will need to be at least 16 feet long.
This is a very simple job which you can DEFINITELY do yourself if you just take your time. Most of the time is spent removing trim pieces and figuring out how to run the power from the battery into the car (easy to find, hard to get at), and then figuring out how you want to mount it in the trunk. If you have the time and the energy, you could save a lot of money! Plus, you'll have the satisfaction of having done it yourself
Old Mar 23, 2003 | 05:53 PM
jmh8's Avatar
I would like some more input from you about the infinity if you don't mind. How does it sound? Did you remove your BOSE sub? The guys at the stereo shop by my house are trying to talk me out of the basslink. They say that I would be better off going with a 10" sub and separate amp. They also said the Basslink sounds much better in trucks-of which they were supposedly designed for? I have never heard one in a car so I just want to know how the sound is. Thanks
Old Mar 24, 2003 | 08:04 AM
The Basslink is an affordable option for anyone who wants to enhance their stock or aftermarket headunit. I had it set up with the stock BOSE HU.
Since then I have upgraded to an Alpine XM headunit with SUB outputs. The Basslink really thumps and having the in cabin remote is awesome. The other attractive option is being small in size. I have it mounted in the rear left side of my trunk. I still have almost a full trunk to work with.
My car thumps more than enough for me and I really enjoy the sound. If I have the need to crank my music I can.
I would recommend this set up for anyone looking for a $219 amplified subwoofer.
D
litch
123
Jan 4, 2024 07:01 PM
9aj9
Apr 5, 2020 12:11 AM
trsandrew
Apr 8, 2016 06:45 PM
RinconI30
Nov 10, 2015 10:55 PM
trsandrew
Oct 25, 2015 02:47 PM
