My custom trunk, just starting, dont laugh =)
Old Apr 30, 2003 | 07:46 PM
D1NOnly34's Avatar
Well, for the past week, I have been working on customizing my trunk. I had to stop for a bit because of finals and so forth. Yesterday I began to proceed with my project. I bought 3/4" MDF wood from Home Depot, I measured the wood there and asked them to cut it. They didnt do a good job, so I had to recut the sides slightly so they were straight. I bought all the supplies needed, and began to work. Here is a pic of the outside of my house where I worked, I know, not professional like, but its the best I can do with a low budget and a one man team. =P
My Work Area LoL
Due to low batteries on my digi cam, I couldnt take detailed photos. A couple of hours later, this is what I ended up with. BTW, I got my inspiration from Freddie (97gles) thanks for the pointers
First Pic
Second Pic
Third Pic
I wanted to finish but then it started to get black, and it rained like crazy. Its been raining ever since. I know its not that good, but I think for my first time at it, I didnt do too bad. BTW, the little peice of wood is just there to make the boxes even with each other. The trunk floor slopes downward, so I will have a 2 x 4 running across the bottom/front of the boxes. Keeping them sturdy, aligned, and in place. The boxes look huge, and are huge! They are calculated to have the right amount of cubic feet of air to make each sub sound perfect. Yes I did take out the displacement of the sub and thickness of the wood, etc. before I made the box, took me a lot of calculating and drawing before I actually started. Again no laughing, just let me know what you think. Thanks!
Devon
Old Apr 30, 2003 | 07:48 PM
Supa Lao's Avatar
That's starting to look like a really good install. Good job
Old Apr 30, 2003 | 08:01 PM
gtr_rider's Avatar
192.168.1.1
Nice!
Old Apr 30, 2003 | 08:03 PM
jmax
Good start. You got more done than I ever do in a weekend. I start a project, then my wife intervenes and I end up spending the rest of the weekend doing something in her car.
Old Apr 30, 2003 | 08:05 PM
D1NOnly34's Avatar
Thanks!
Old Apr 30, 2003 | 09:07 PM
97GLES's Avatar
Originally posted by D1NOnly34
Thanks!
looks really good.
keep the pics coming.
if you need any info feel free to call me.
Old Apr 30, 2003 | 09:50 PM
maximamaybe's Avatar
Nice work. Keep us posted.
Old May 1, 2003 | 04:27 PM
D1NOnly34's Avatar
If you guys have any pointers or see somethign that should be done with my setup, please feel free to tell me, I'm up for any ideas that can help me out and improve what I have so far, I;ll keep you guys posted.
Old May 1, 2003 | 09:59 PM
white90se's Avatar
what if you angled the boxes a little...so the subs were facing each other a little more...the boxes look big so i dont know if you would have enough room to do it like that...it was just a thought i had...i might try to do that with my 3rd gen...i think it might look better then just 2 boxes looking straight at you when you pop the trunk...i was also wondering where you are mounting the amp??
will
Old May 1, 2003 | 10:14 PM
D1NOnly34's Avatar
Well my idea was to kind of create a space in teh middle for easy bass flow. By angling I probably would be using more space, and then having lots of small areas free and not useful. Angling the boxes would most likely remove the middle space, and also you have to remember that you can't angle too much, or else the subs will cancel each other.
Old May 1, 2003 | 10:36 PM
white90se's Avatar
thats true...i wouldnt angle too much anyway...but i know what you are saying about space...i figured angling them would take up more space...it was just a thought
Old May 2, 2003 | 06:29 AM
D1NOnly34's Avatar
Thanks for your idea though
Old May 2, 2003 | 08:27 AM
studman's Avatar
1) Look at my homepage for some ideas.
2) Make sure you secure the boxes to the floor.
3) Make sure to seal all the cracks so no air leaks.
4) Keep up the good work.
Old May 2, 2003 | 10:29 AM
AphexX's Avatar
tight work... keep it up
Old May 2, 2003 | 02:17 PM
Methamphetamine's Avatar
I think you're doing ALOT more work than you could. Unless you already thought of that. Well...in different ways I see it - It'll be phat. Are you going to carpet the boxes?
Old May 2, 2003 | 11:25 PM
D1NOnly34's Avatar
Well, I had to think and draw up a plan of the boxes before I actually did anything. Measuring the trunk, finding out the specs on the subs, the wood, calculating cubic feet of air, etc,and still have enough room for my amps and all other things. When the setup is finished, it will be carpeted, gonna look all nice and pretty
Old May 17, 2003 | 04:39 AM
D1NOnly34's Avatar
Sorry for not keeping you guys up to date, school and work is killing me, but I was finally able to finish the two boxes for my subs. Hoenstly I was a little nervous because I wasnt sure if it would sound good, considering this is the first time I actually made subwoofer boxes from scratch. I used lots and lots of caulk (inside, outside, and between each peice of wood) so absolutely no air would leak out. I think it sounds really really good. I can tell that the subs kick harder and sound a little more clearer now. My volume goes up to 40, but I dont go past 15 because of a lot of bass, and plus I dont have everythign finalized. All the bass options are on its lowest level, which means I cant wait till everythign si complete to start creating some heavy bass. I'm going to take some pics of what I have so far when I get out of work.
Old May 17, 2003 | 06:48 AM
nupe500's Avatar
Jedi Knight
nice keep the updates coming...
Old May 17, 2003 | 08:24 AM
AphexX's Avatar
pics
matts95max
Apr 23, 2025 10:44 AM
Maxboy23
Sep 4, 2015 06:04 PM
trungg86
Sep 4, 2015 04:58 AM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
