put 6x9's in my rear deck.
Old May 7, 2003 | 08:15 PM
99maxi's Avatar
had some time the other day and it was nice outside so i did this..
http://www.unl.csi.cuny.edu/~wai/DSCF0046.JPG
it too about 2-3 hours to do..
Old May 8, 2003 | 07:02 AM
Dohcser's Avatar
Re: put 6x9's in my rear deck.
Nice job! What do you have in your rear doors?
Old May 8, 2003 | 07:05 AM
99maxi's Avatar
Re: Re: put 6x9's in my rear deck.
nothing in my rear doors yet.. this is just the start of my audio setup..
Old May 8, 2003 | 02:53 PM
ny96max's Avatar
you might wanna install some dynamatt under those. When i did mine i rolled on about 2 layers of Dynamat Extreme.
Ant
Old May 9, 2003 | 05:05 AM
Dohcser's Avatar
Re: Re: Re: put 6x9's in my rear deck.
The reason why I asked is, I am not sure if you going to be competing or how involved you will get with your system. But too many speakers in the rear takes away from the front imaging. If you were to compete in SQ, that is a not a prefered setup. If you are just doing for your enjoyment and don't care about imaging or competing, it dosen't matter! Just thought I let you know.
Oh and you definately want some sort of sound dampening on your rear deck.
Old May 10, 2003 | 03:04 PM
Supermax95's Avatar
nice job....i bet u had to do some nice metal cutting like i did...i did mine a little differently though...i added a 1/4" fiberboard sheet to the surface the give the speakrs a perfect seal...i had no problems whatsoever with rattles or anything....
Old May 10, 2003 | 04:11 PM
99maxi's Avatar
Re: Re: Re: Re: put 6x9's in my rear deck.
i am just doing it for enjoyment..
i had to use a dremel to cut the hole.. it fits tight so i decided that i did not need something to seal it..
jskirwin
Jun 8, 2016 08:49 AM
Huttig2009
Sep 25, 2015 03:31 PM
Maxilano
Aug 31, 2015 07:33 PM
doobadoo
Aug 15, 2015 06:43 PM
sc10692
Aug 9, 2015 09:37 AM
