What is the size of the Stock speaker?
Old May 27, 2003 | 11:18 PM
crsh2's Avatar
Sorry to post a lame Question but my 2 rear speaker is horrible and really need to replace them.
I Need to know the stock size so i can buy it in ebay, I really
dont want to put any bigger hole or cut anything out.
Thank you in Advance
Old May 27, 2003 | 11:21 PM
BuNGsVQ's Avatar
do you have the Bose system?
Old May 27, 2003 | 11:22 PM
BuNGsVQ's Avatar
I think the stock size w/o Bose is 6 3/4"
Old May 27, 2003 | 11:24 PM
crsh2's Avatar
Sorry forgot that info.
No. Its not bose
Old May 27, 2003 | 11:28 PM
98maxsel's Avatar
its 6.5 inches all around.
Old May 27, 2003 | 11:29 PM
crsh2's Avatar
Thank you Sir. Have a good Night!!
Old May 28, 2003 | 12:12 AM
ch13f's Avatar
Actually, I believe the size all around is 6.75", 6.5 will work too though.
Old May 28, 2003 | 12:45 AM
drewbowski's Avatar
First off please pm if you are talking about upgrading stereo equipment. You don't want sound in the rear. Do you go to a concert and turn your back to the stage. i thought so. trust me. i'm in to high end car audio. i can help you. or i can sell you my bose system which is ****. let me know you wont' be disapointed.
Old May 28, 2003 | 03:38 AM
geo1317's Avatar
Originally posted by slammed95
Are you saying to not use rear speakers? That's lame. I don't think you would want to put a sub box up front, and I'm sure the rear passengers would like some good sounds.
If your into high end audio, you should realize you can't just have front speakers.
it all depends on what you are going for, if you want a good stage and SQ, then rear speakers are a no-no(maybe some mid-bass speakers, but even those). But if you want to go loud and don’t care about SQ then speakers in the back are no issue. As for subs, anything under 100Hz is not directional so you can’t tell if its behind you or in front of you, so having them in the trunk is fine.
Old May 28, 2003 | 06:01 AM
Sprint's Avatar
Actually you can only run with front speakers, rear speakers are purely rear fill aka mid range. If you are getting good mid range from your fronts then you can run without rear speakers no problems.
My Setup:
Diamond Audio Motorsports (front)
Diamond Audio Hex (rear)
ID Max D4 (sub)
My Cousin's Setup:
Diamond Audio Hex (front)
Audiomobile (sub)
My Other Cousin Setup:
ID Max D4 (sub)
The Diamond Audio Hex have better mid range than the Motorsports so they chose not to run with a rear speaker, howeever i took my mid bass from my hex in the rear.
I have a little more definition in my Front Stage but otherwise the cars sound pretty much the same.
To keep it to the original Topic:
stock speakers are 6.5S aka 6 3/4, but you can get away with 6.5
Old May 28, 2003 | 10:02 AM
95GreekMaxSE's Avatar
6 3/4 all around will be direct swap, 6 1/2 will need deeper cut for speaker to fit and 6 flat even deeper. Any smaller than 6 needs fitting rings. go with 6 3/4 for direct swap.
9aj9
Apr 5, 2020 12:11 AM
05' MaximaMan
Oct 8, 2017 06:36 PM
RIPTIDER
Wheels/Tires
Jan 31, 2016 07:39 AM
mikeymouse1995
Sep 18, 2015 06:42 AM
meccanj98
Sep 16, 2015 07:23 AM
