Bose radio relay location??
Old Jun 15, 2003 | 05:22 PM
elcid's Avatar
My radio is out no music (going crazy) Checked the fuses and they're all fine. I noticed when I was driving it kind of was cutting out and in, and then died. maybe it's the relay. Anybody know where it is located? Kind of weird thought the CD was skipping but saw the display was flickering off and on, and then just never came back on. Does the radio have a fuse located on the back of the radio? I have no idea where the relay is located.
Old Jun 15, 2003 | 05:29 PM
dwapenyi's Avatar
I'm not certain, but I usually here a clicking by the front passenger's right foot area whenever I turn the Bose on.
DW
Old Jun 15, 2003 | 05:40 PM
elcid's Avatar
Y aI remember hearing it from tehre also, nto surte if maybe that was for the speakers or not since they have amps on them. Hmmm....Anybody else know how I can get the music going again?
Old Jun 15, 2003 | 06:11 PM
TylerBorg's Avatar
Buy a new system??? AFTERMARKET OWNS BOSE
Old Jun 15, 2003 | 06:36 PM
elcid's Avatar
Not really the solution I was going for, but yes I have thought about it. But money is tight, got a big trip coming up. Any other solutions?
Old Jun 15, 2003 | 09:22 PM
Indecisive311's Avatar
You could just buy just the head unit for now. You would have to rewire the entire system at every amp though. It costs about 60 dollars to get it professionally done.
Peace - Chad
Old Jun 16, 2003 | 05:38 AM
elcid's Avatar
Why you think it's the unit that's dead? Do they die often or something? I would think that it's just a bad connection or relay or something?
Old Jun 16, 2003 | 07:54 AM
cam_honestiam's Avatar
Pull the radio out of the console and check for continuity in the ground and power cables going into the head unit. If it was flickering, chances are that going over a few bumps loosened or shorted something out. Start simple.
Old Jun 16, 2003 | 08:00 AM
dwapenyi's Avatar
Try one or both of these things;
Pull the appropriate fuses and put them back again. If that don't work,
Dis-connect the battery for a while and connect it again.
I've seen threads on here saying that these things work.
DW
Old Jun 16, 2003 | 08:05 AM
elcid's Avatar
Cool. I'll give it a try after work today. No music is the worst!
Old Jun 16, 2003 | 08:07 AM
elcid's Avatar
Does anybody know the location of the radio relay? My hanes manual kind of shows it being int he center concole. I took apart the center console and only found some electrical box for my air bag system, no relays anywhere. Any ideas of the lcoation of this relay?
Old Jun 17, 2003 | 10:53 PM
1FSTMAX's Avatar
On my 97' it's on the passenger side kick panel.
Old Jun 18, 2003 | 06:05 AM
elcid's Avatar
Ya I found the relay. I switched it with relays under the hood, using the same relays model of course. BUt it didn't work. I think maybe the radio is cooked?
Max139617
Sep 29, 2015 06:44 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
