Solobaric L7 with a Rockford 700s???What do u think?
Old Sep 4, 2003 | 10:14 PM
BORQUA79's Avatar
nycmaximas member
I have a L7 Kicker 12" Sub and im deciding on a 700s the older model of Rockford amps. The L7 12" RMS is 750, and the Rockford Amp RMS is 700...Would that work? Or will i damage my sub? How does it work out when deciding how much power is enough or too much for a sub? And where does the ohm's come in? What if the sub is either 4 ohm or 2 ohm? what does that do for me? Thanks for all the input im clueless...one
Old Sep 4, 2003 | 10:33 PM
AscendantMax's Avatar
that RF amp will put out more than 700 watts. it would like like 730 - 750 (perhaps more) in true wattages. my RF amp pushed out 45 more watts than listed. it should tell you on the amp's birth certificate
Old Sep 5, 2003 | 01:44 PM
BORQUA79's Avatar
nycmaximas member
I heard the same thing about rockford...But when it comes down to haveing the right amount of power...how much watts should i consider for a solobaric L7 that runs 750 RMS? Should it be as close to 750 as possible? What if i run too little or too much power ?(watts)?
Old Sep 5, 2003 | 08:52 PM
97GLES's Avatar
the RF amps are tested most of the time with 14votls or more. check your sheet.
Old Sep 7, 2003 | 09:33 AM
D1NOnly34's Avatar
RF amps usually put out way mroe than advertised, i have a 700s and it pushed around 830 watts, i have 2 12" HE2s, but am switching them with my new L5's, should be a good combination
Old Sep 7, 2003 | 03:35 PM
BORQUA79's Avatar
nycmaximas member
Thats cool, but if my sub is 750 RMS would that 700s running around 830 be too much for my sub? or could it work? Or should i run less power to one 12" L7?
Old Sep 7, 2003 | 05:59 PM
kenji's Avatar
You want an amp that can push more than needed. The gain on your amp shouldn't be turned all the way up, this can cause clipping and can damage your sub. That amp should work fine, but I would not advise running the amp at full power, instead set the gain a little higher than 3/4. With an L7 that should be loud enough to make you go deaf anyways, so enjoy your hearing while it lasts.
Old Sep 12, 2003 | 02:02 PM
Torgus's Avatar
is that amp rated at 700 peak ? most amps say they do 700w. but really only do the peak w when bridged @ 1 ohm. L7s can do 750rms, means they can handle about 11-1200 w peak. i hear L7s love power. enjoy your thump, your **** is gonna bump!
Old Sep 12, 2003 | 02:37 PM
Gjohnson's Avatar
From what I've always been told, RF amps are rated at continuos power. Like posted above, I would run that amp at about 3/4 on the gain. And just cheeze.
Old Sep 13, 2003 | 02:20 PM
BORQUA79's Avatar
nycmaximas member
that all sounds cool...thanks
Old Sep 16, 2003 | 06:48 AM
S103100F's Avatar
i have 2 L 7 12' and my car is almost falling apart those things are a loud and RF is a very good amp and by the way is beather to take more power full amp than less i am about to change my Kicker 02KX800.2 coz that s**t sucks big time and what ever you do dont take kicker amp what do you think i should get ?
Excalibur23
Oct 13, 2015 04:33 PM
bryants95max
Oct 2, 2015 12:52 PM
702maxi
Sep 1, 2015 09:27 AM
