Looking 4 XM Radio setup Pic?
Old Sep 21, 2003 | 02:49 PM
esc92's Avatar
Please post pics of ur setup of the SkYFi radio receiver or anyother receiver you have in your car. I'm looking for ideas of wear to place a receiver in a 2K1 Max. Help! THANKS IN ADVANCE
Old Sep 21, 2003 | 07:20 PM
NyMaxedOut's Avatar
Try clubxm.com. On that site, they have a section where you can view pics of installed systems. I believe there a 4th or 5th gen on there. Not sure. Ck it out ...
Old Sep 22, 2003 | 03:07 PM
kronnman's Avatar
I have Sirius and I installed my controller in my sunglasses holder.
Check it out.
Old Sep 22, 2003 | 04:54 PM
esc92's Avatar
Check it out.
That's a tight setup! How did u run the wire from up there? Is it easy to close? Ur still able to play the XM when it's closed, right?
Old Sep 22, 2003 | 05:14 PM
kronnman's Avatar
Thanks,
I removed the assembley where the sunglasses holder is located. I made a slight modification to the sunglasses holder so that I could run the wire. I ran the wire in the roofline on the drivers side and then removed the A pillar on the drivers side to get the wire to the harness I ran along the left side of the car. And yes, it closes very easily out of view and it will play when it is closed.
The only way that someone can tell I have satellite is from the antenna that I have on the roof. It is not that hard to do. It just requires alot of patience. I have had Sirius for 6 months now and I would never go back to regular radio.
Old Sep 22, 2003 | 08:25 PM
Nismo's Avatar
check out www.XMfan.com
Old Sep 24, 2003 | 01:15 PM
TAPOUT's Avatar
You will lose
You can also use a pro-fit mount that you can buy from most cell phone shops if you are going to go with the skifi
Old Nov 23, 2003 | 11:24 PM
nismaniac's Avatar
Thought I would bump this as opposed to starting a brand new thread. I looked at those links and didn't find what I was looking for. If anyone has installed the Delphi skyfi or Roady, I would really appreciate pics. Also, I will probably go the casette adaptor route to keep the stock head unit. Any help is greatly appreciated.
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
