? about CD changers (FM modulators)
Old Feb 21, 2001 | 08:22 AM
MaximaRacer's Avatar
Right now I have an add-on cd changer which is a FM Modulator which means I have to open the radio everytime I want to listen to a CD. If I install a new tape deck with a cd receiver do I still have to use the radio to listen to the CD?
Old Feb 21, 2001 | 12:33 PM
CanuckAMP's Avatar
Make sure you get a CD deck that can control your changer. (ie. it should be the same brand and use the same protocal language). Then when playing CD's from the changer the interface will be a straight analogue signal from the changer to the headunit in the dash. If you go with a different brand deck from your changer you will be left with no alternative than to still us the RF FM interface.
Old Feb 21, 2001 | 12:35 PM
CanuckAMP's Avatar
Make sure you get a CD deck that can control your changer. (ie. it should be the same brand and use the same protocal language). Then when playing CD's from the changer the interface will be a straight analogue signal from the changer to the headunit in the dash. If you go with a different brand deck from your changer you will be left with no alternative than to still use the RF FM interface.
Old Feb 21, 2001 | 07:50 PM
the problem is that my changer is a factory changer and i think its and Audiovox and there aren't much audiovox decks
Old Feb 22, 2001 | 06:07 AM
CanuckAMP's Avatar
Well it might have been supplied by the dealer but it's not actually a factory changer. If that was the case they would have set you up with a Sony Unilink type changer or an OEM Clarion unit (if one exists) and used an interface to get it to work with the factory deck so you didn't have to use the FM modulator setup. Audiovox does make headunits though, but I doubt that's one that you will want. It would certainly be a downgrade from the factory deck.
I suggest your only option may be to look into an entirely new AM/FM/Tape/CD/changer combination (any brand) or get an indash AM/FM/CD changer that are made by Nakamichi or Eclipse.
Old Feb 22, 2001 | 07:10 AM
THANKS A LOT CANUCK!!!
Old Feb 22, 2001 | 07:34 AM
CanuckAMP's Avatar
Not a problem. I'm new here but I've been around the Usenet sites for a while.
Hope I can lend an unbiased opinion here when I can.....
AaronL
Nov 15, 2020 11:52 AM
Robert Schneeweis
Jan 11, 2017 06:47 PM
jsmith24
Feb 1, 2016 12:35 AM
knight_yyz
Nov 1, 2015 01:34 PM
