grounds
Old Nov 16, 2003 | 05:51 PM
sk24iam's Avatar
grounds
What kind of groud have you guys been suing. First I used the bolt where the rstb would go but that wasn't good, and now I'm using the one next to where the jack is and that one sucks too. What is everyone using?
Old Nov 16, 2003 | 09:15 PM
foetray's Avatar
On each side at the back of the trunk under the liner there are two bolts that hold the bumper to the frame. I grounded mine there.
Old Nov 17, 2003 | 01:30 AM
lunchbox's Avatar
I used the bolts that hold the trunk latch. There is also a spot along the front of the trunk(closest to the bumper) that has a factory ground. I used that bolt as well. I had 4 grounds right in that area, and they all worked without issue.
Old Nov 18, 2003 | 09:59 PM
jmax
Rear left and right side the trunk widens a bit. Drill straight through and you can hit the frame. That is a good ground. Use the largest brass bolt you can find.
pktaske
Sep 4, 2015 08:40 AM
