Different Guages work?
Old Nov 26, 2003 | 04:31 PM
OpTi's Avatar
My power distro block only has 4 8 guage outputs. The amp i want needs 4 guage power cable. What will happen if i use 8 guage? Sorry if this is a very very very very stupid question. Thanks
Old Nov 26, 2003 | 05:49 PM
AscendantMax's Avatar
i don't see any problems as long as the 8 gauge going into your amp ISN'T LONG. so you might have a 1/0 gauge going into your distro block in your trunk, from there 8 gauges to your amps.
Old Nov 26, 2003 | 06:30 PM
OpTi's Avatar
I have a 4 gauge going into my distro block. The 8 gauge will probably be 3ft max. You think it will work?
Old Nov 26, 2003 | 08:33 PM
how much is that amp putting out?
Old Nov 26, 2003 | 09:18 PM
EriCCirE's Avatar
thats dumb, it will only get the amount of power from the weakest (or smallest) part. Doing it that way will be just like wiring the whole thing with an 8 Gauge wire, which wont supply enough power.
Old Nov 26, 2003 | 09:34 PM
no...
power decreases as the line get longer. if he had an 8 gauge from the battery to the trunk then yes that'll be bad. but he's running a big wire to the disto block. then from there smaller gauge to his amps. if the wire to his amps are relatively short, i don't think it'll be a problem, unless his amps are putting out big power.
Old Nov 27, 2003 | 09:08 PM
OpTi's Avatar
the amp i want to get is the RF 500bd. I'm gonna wire it in 2 ohms to 2 subs so it should be putting out 500 watts. If the 8 guage is less than 3 feet, do you think that it will be a problem?
Old Nov 27, 2003 | 09:19 PM
it will be fine. don't go over 4 feet though. the shorter the better.
Old Nov 28, 2003 | 08:14 AM
OpTi's Avatar
It will probably be even shorter than 3 feet. Thanks!
Old Nov 28, 2003 | 09:34 AM
no problem. if you want even more info check this site out
http://www.the12volt.com/wiring/recwirsz.asp
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
