What speaker wires for Components/Basslink?
Old Dec 6, 2003 | 09:23 PM
speediq99's Avatar
Hello,
I am planning to install Kappas 60.5 components. Can I use the stock speaker wire on my 2003 Maxima non-bose? If not what gauge wire do people use on these components?
Does someone know what the best way is to get to the battery? I have not found a good way to get thru the firewall. There is a small plastic grommet on the firewall (driver side) but I can't fit 8 gauge wire through and drilling a bigger hole is going to be a challenge.
I purchased a Basslink and I am about to buy an amp to run the components. What is the best way to get power to the amp? Do I run another line to the battery or ???? I am planning to use 8 gauge wire with the basslink. Is this good enough?
Thanks,
Mike
Old Dec 6, 2003 | 09:34 PM
nismos14's Avatar
§è~® f®ÈÄk
u can use the stock wires. use 4 guage wire and run it to a distribution block. from the dist block run 8 gauge to each amp. where do u plan to mount the 4 channel amp?
Old Dec 6, 2003 | 09:38 PM
speediq99's Avatar
I am planning to mount the Basslink in the trunk. The Amp will probably go there as well.
Do you have any idea of how to get to the battery from the inside?
Thanks,
Mike
Old Dec 6, 2003 | 09:45 PM
nismos14's Avatar
§è~® f®ÈÄk
not sure since i dont have accest to a 5th gen. but i definately suggest running a 4 gauge power wire. i have my hole drilled under the brake booster on the fire wall
Old Dec 7, 2003 | 06:42 PM
speediq99's Avatar
Thanks for the information.
I noticed that the Basslink calls for a 20Amp fuse while the amp that I am planning to use requires a 30amp fuse. How would I handle this running a 4 gauge wire to the Dist. Block and a single fuse?
Thanks,
Mike
Old Dec 7, 2003 | 07:24 PM
carabuser's Avatar
Alrite, I had this same problem as well. I guess the only way is to drill a few holes to get that cable. Go to
http://www.max-world.org/frames.htm
Then on your left there's that How-To section. Scroll down to "Electrical" and choose "Run a wire through your firewall" (direct link: http://www.max-world.org/writeups/5t.../firewall.html )
Very nice guide-lines and quality pics. Good luck!
Old Dec 7, 2003 | 09:40 PM
nismos14's Avatar
§è~® f®ÈÄk
put a 50 or 60 amp fuse on the 4 gauge cable near the battery.
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
