it ok to mix different ohm subs?
Old Dec 9, 2003 | 08:59 PM
AscendantMax's Avatar
is it ok to mix different subs with different ohm ratings? if i have two 4 ohm SVC subs and add a 8 ohm dvc sub, wired in parallel, what would the final ohm load be on the amp?
thanks in advance for any replies
Old Dec 9, 2003 | 09:21 PM
jmax
everything in parallel or the two 4 ohm subs in series and then in parallel with the 8? Regardless you don't want to do it because the subs won't share the amps power equally.
Old Dec 9, 2003 | 09:30 PM
oh good point. i want to add another 10" to my setup. i have two 4 ohm dvc subs right now, and with three 4 ohm subs wired in parrallel, i'll see a 1.34 ohm load. i know not many amps out there are below 2 ohm stable. you recommend any amps that can handle the load?
edit: i have SVC subs, not DVC
Old Dec 9, 2003 | 09:40 PM
jmax
There are a multitude of class D mono sub amps that are 1 ohm stable. Pick any of them. But figure out your ohm load first. You indicated you have a pair of dual 4 ohm subs and that you plan to get one additional single voice coil 4 ohms sub. Is that right? Three dual 4 ohm subs can be wired 2.7 ohms or 6 ohms easy.
Old Dec 9, 2003 | 09:47 PM
yes i have two 4 ohm scv subs right now and planning to get another one.
how did you get 2.7 ohms? isn't it: sub ohm / # of subs? so 4 ohm / 3 = 1.333
i'm still kind of new to this ohm thing
Old Dec 9, 2003 | 10:09 PM
jmax
Sorry, in your second post you indicated 4 ohm dvc. Therefore six 4 ohm coils.
12 / 2 = 6
4 / 3 X 2 = 2.7
Old Dec 9, 2003 | 11:13 PM
oops, sorry about that. i meant svc.
jmlee44
Oct 2, 2022 02:13 PM
bryants95max
Oct 2, 2015 12:52 PM
Redfox
Sep 28, 2015 10:41 AM
msellas
Sep 23, 2015 09:16 PM
pjgreek
Sep 9, 2015 09:30 PM
