4th Gen Wire Codes for Alarms inside
Old Dec 10, 2003 | 08:05 PM
C3nthusiast's Avatar
1995-1999 Nissan Maxima
12volts wht/red - wht/pur + ignition harness
Starter blk/yel - blk/wht + ignition harness
Second Starter grn/blk - red/blu + ignition harness (cold start wire)
Ignition blk/wht - blk/red + ignition harness
Accessory red/yel - red + ignition harness
Second Accessory blue - wht/blu + ignition harness
Power Lock lt. green/red - in drivers door at switch
Power Unlock green/yellow - in drivers door at switch (double pulse)
Lock Motor brown/white in drivers door at switch
Unlock Motor brown in drivers door at switch
Parking Lights red/green + steering column
Door Trigger red/white - low in drivers kick
Trunk/Hatch Pin purple/yellow - drivers kick or BCM
Hood Pin yellow/black - hood pin
Trunk/Hatch Release purple/yellow - low drivers kick
Factory Alarm Arm arms w/ lock
Factory Alarm Disarm disarms w/ unlock
Tachometer white/green or * AC ECM (below radio) or *injector wire (non common wire)
Brake Wire red/green + at brake switch
Horn Trigger green/white - steering column
1999 needs bypass module for remote start. Requires extra key. DEI part# 555U or you can make it yourself using a relay.
I have the codes for all Maxima's if you need them.
Old Dec 13, 2003 | 06:37 AM
s0ber's Avatar
thanks
kjlouis
Nov 24, 2018 06:09 AM
Finkle
Sep 27, 2015 09:53 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
doobadoo
Aug 15, 2015 06:43 PM
Blackwind
Aug 5, 2015 06:35 PM
