fuse holder or circuit breaker?
Old Dec 16, 2003 | 08:34 AM
sk24iam's Avatar
I sued to use a fuse holder but I recently switched to a circuit breaker. I find that when working on your system it's easier to just hiot the switch than take the fuse out.
Old Dec 17, 2003 | 12:46 AM
HitManSE's Avatar
Use both
Old Dec 17, 2003 | 10:03 PM
nismos14's Avatar
§è~® f®ÈÄk
depends. if ur using a circuit breaker with too high of a rating then u run the risk of frying ur amp in the event that the circuit needs to be broken by either burning out the fuse or setting off the circuit some how. the circuit will not break if the amperage of the circuit breaker is too high.
Old Dec 17, 2003 | 10:18 PM
HitManSE's Avatar
Personaly, I have two ANL 100amp fuses, two waffer 60amp & two waffer 40amp fused. Its just safer IMO.
Old Dec 20, 2003 | 05:14 PM
maxu4ia's Avatar
This is an interesting discussion. How often do you blow a fuse?
Old Dec 20, 2003 | 10:25 PM
nismos14's Avatar
§è~® f®ÈÄk
i have yet to blow a fuse in my system, its been like 4 1/2 months
Old Dec 21, 2003 | 12:14 AM
jmax
I don't think I have blown a fuse in the stereo for about 12-15 years. Can't remember if I have ever, in the main section of the car stereo.
For the main power fuse or any fusing application for amps I would use a fuse. Reason is that the fuse is more relieable. Or more accurate. A circuit breaker also has greater resistance than a fuse - therefore greater voltage drop.
If you want to go high end I would use an ICB, Intelligent Circuit Breaker. They have more benefits than a standard breaker and lower resistance than a fuse.
Old Dec 22, 2003 | 04:13 PM
kosd's Avatar
You could always put the breaker and fuse in series too...
Old Dec 23, 2003 | 06:07 AM
jmax
Why use fues or breakers in series? They are both resisters. The more resistance you have in line between the battery and amp the less voltage you will have at the amp.
gavin68
Sep 18, 2021 12:36 PM
leatherneck
Sep 30, 2015 09:16 PM
