Need Help.....
Old Feb 12, 2004 | 07:43 AM
Cashj2002's Avatar
Need Help.....
I have 2 12inch subs and 1 600 watt amp running a 4 guage wire from the batter. Never had any problems! After I hooked up my APC and autometer guages which consist of APC voltmeter and autometer air/fuel C2 guage .
So I go driving and all of a sudden my system cuts out and head lights dim.
I alread had it checked and its not the alternator.
As far as how the guages are hook up, I have both the voltmeter and A/F guage running off the same power and the running off my dash lights. I have both grounds going into my car alarm ground.
Old Feb 12, 2004 | 02:33 PM
nghtfthlngknvs's Avatar
try spearate grounds. common grounds can cause problems. make sure you ground to unpainted parts of the frame. do your lights only dim at high volumes when there is a lot of kick from the subs? you could need an alternator with higher amperage or maybe a cap. try the ground solution first though.
Old Feb 13, 2004 | 09:44 PM
jmax
Your dash light wireing is probably only good for about 10 amps. I would use a new fuse direct to the battery for the power wire.
Old Feb 13, 2004 | 10:47 PM
does the system come back on? could just be a fuse. god knows i've blown a number of fuses working on my car.
L_U_D_I_AMaxima
May 6, 2011 05:12 AM
slow_n_low
Jun 3, 2009 06:45 AM
Padsy
Sep 29, 2003 05:51 PM
