Rewiring???????????????
Old Feb 14, 2004 | 11:10 AM
DoNcHoYaX1's Avatar
U have a 95 with bose. Well i decided to go aftermarket. Im rewiring but got stuck. I need to get the speaker wire from the door panel to the car, well actually two, becauwse Im going to mount the cross over inside the panel. So I will need to run a wire to the amp from the cross over, and another to the tweeter. anyone
help please
Old Feb 15, 2004 | 05:00 AM
C MAX's Avatar
help please
first question where are you mounting the crossover. and two is it eletronic or passive..i mounted mine inside my door then split it up to the mid and high, that way you only have to use one wire to run it.. unless you want to control them both seperate. is that the route your going, soundstaging .. and two i brought a adapter from cruthcfield
that located all the wires i needed i tapped off the speaker line from the adapter and by passed the bose amp then just hooked it right up.. with this adapter its a piece of cake...
Sir Tilus
Mar 22, 2016 01:49 PM
Blackwind
Aug 5, 2015 06:35 PM
MacGyver
Jan 10, 2001 05:12 PM
Cumalot
Dec 23, 2000 10:50 PM
perlmax90
Nov 13, 2000 06:10 PM
