Bandpass.xls?
Old Mar 15, 2001 | 07:04 AM
MardiGrasMax's Avatar
Has any one used bandpass.xls? Is it really accurate?
I'm probably going to build a custom 4th order box and would like to be sure that I do it right.
Old Mar 17, 2001 | 07:33 PM
CanuckAMP's Avatar
I've never heard of that one. You might want to try WinISD it does a nice job...
http://www.linearteam.org/winisd.html
Old Mar 18, 2001 | 10:30 AM
That is a nice program. It closley matches the other one but the GUI is much nicer. Thanks
How can I simulate cabin gain and crossover points? How can I simulate the effects of my systems 70hz 12db lowpass filter. Or would I just tune my band pass box to roll off at ~70hz?
Old Mar 18, 2001 | 11:20 AM
CanuckAMP's Avatar
I would set it up to tune the box for what's ideal for your drivers. As far as simulating an extra crossover point the program can't do that, but you could generate numbers from the program in a print out and with a few calculations figure out your own hand plotted graph or one using a spreadsheet data.
Old Mar 18, 2001 | 12:09 PM
So if my crossover is set at 70hz should I tune the box to roll off at 70hz because it wont be getting and frequencies higher than that anyway?
When I set it up that way the WIN I get a little bit of extra lower end extension and a few more db's too.
Old Mar 18, 2001 | 02:14 PM
CanuckAMP's Avatar
I'd likely cross it over higher to get the low pass crossover step working at a frequency above your box tuned frequency. That way your subs will have more efficiency at their tuned frequency of the bandpass box....
