How to mount PS2 in maxima ??????
Old Mar 17, 2004 | 10:42 PM
Magikone69's Avatar
I just wanted to know if anyone can give me some advice on how to mount my ps2 on the passenger side under the dash. I would like to know f anyone has done this and if somebody can give me some advice on how i can securely attach it without worries of it falling out.
Old Mar 18, 2004 | 03:46 PM
Magikone69's Avatar
nobody has ne advice at all????
Old Mar 20, 2004 | 07:23 AM
minsbang's Avatar
i've seen pics of cars with that setup. But I wouldn't put my playstation under the passenger dash because you can see it clearly from outside.
Someone might want your system and break in, which is not what i had in mind.
I would put it in the glove compartment.
Old Mar 20, 2004 | 08:03 AM
Magikone69's Avatar
not sure if it will fit in the glove box, unless i remove theblack piece in there(the actual compartment) and custom make something else. I have 5 % tint and it is hard to see inside, ill do a little test and put my ps2 on the floor and look in to see how noticeable it may be. still confused on which route to go
Old Mar 21, 2004 | 06:07 PM
minsbang's Avatar
oh, if you have tints, then install it under the dash like you wanted to.
I went on Cardomain.com and checked out lexus gs300/400's and some of them had it
Old Mar 21, 2004 | 10:31 PM
Magikone69's Avatar
now im thinking about the trunk, seems like a nice safe place and i keep it locked, but then again it will be a PIA to change games. unless i have it accesible by the oppening in the back seat. TV is supposed to be here monday so i will try to install everything on my day off which is thurs and fri
Old Mar 22, 2004 | 10:18 AM
minsbang's Avatar
putting the ps2 in the trunk will be a PIA.
my friend bought a game cude, which he put in the arm rest. and he got the wireless controls and it's hot. Of course the games and the graphics aren't as great as ps2 but it's still hot.
you might be able to mount it sideways on the rear center arm rest (the plastic piece)
Old Mar 24, 2004 | 09:29 PM
EteRnity059's Avatar
Boosted?....
You can mount it under the passenger seat. The only thing you will lose is the mobility of the seat. You will not be able to move it forward any more. As for convenience, it is very easy to change games and power it up.
I have my ps2 mounted under my pass seat with wireless remotes. My pass seat is permanently set in one position. Trust me, even with 5% someone will see or be curious as to what you are hiding. It's better to be safe than sorry. Mount it under the glove box and if someone decides to yank it out, you are f**ked
Old Mar 25, 2004 | 07:25 AM
Magikone69's Avatar
well after about 2 hours of work everything is done(completed thurs march 25 at 10am), i mounted the ps2 under the dash and trust me it is not visible at all!!!!!!!! only way you will see it is if you smash the window and stick your head in. i will post pics in another thread once i get a hold of a camera
schmellyfart
Sep 25, 2015 04:47 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
