'02 Maxima install - Almost done..
Old Mar 21, 2004 | 09:49 AM
Audtatious's Avatar
Bandwagon Lover
Well, I'm almost done with the audio install. Pretty basic system, IMO...
Equipment:
--- Factory 6CD Bose HU
--- PAC adapter
--- Carver/KLW Phantom Bass Processor (questionable if I install it)
--- Precision Power PAR-225 Quasi-parametric pre-amp/EQ
--- AudioControl 24Xs crossover
--- a/d/s PH15 amp (bridged 3-way @ 178wpc)
--- JL Audio 12w6
--- Infiniti Reference 6000cs seperates (6.5" mid + tweeter)
--- 2ea Stinger 1fa capacitors
Everything is installed except for the Phantom Bass and AudioControl crossover which is still on order and has not arrived. I will be documenting the complete installation and will post up the link when I am done. Here's a couple of pix of it in progress:
Old Mar 21, 2004 | 01:14 PM
slickrick's Avatar
looks good. i should have used the stock mounting kit for the speakers like you did. i went out and bought a spacer kit for mine instead.
Old Mar 21, 2004 | 02:17 PM
nismos14's Avatar
§è~® f®ÈÄk
that does look good, can't wait to see the write up
Old Mar 21, 2004 | 06:10 PM
Audtatious's Avatar
Bandwagon Lover
It does not sound too bad at the moment. I had a set of MB Quart seperates with Musicomps that I replaced when I picked up the Infinity's. I have not replaced the MusiComps yet, so they seem to get more bass than I want. The Xover and installing the Infinity xovers will help. Sub is running full-range right now which is kinda funny
I have a writeup available for installing front speakers:
http://www.win.net/audtatious/audio/...ont-doors.html
Old Mar 29, 2004 | 04:50 AM
Audtatious's Avatar
Bandwagon Lover
Another update.....I have most of the stuff buttoned down and wire loomed. AudioControl 24Xs was installed, but is injecting noise onto the system, so I need to open it up and play with the ground level switch. The Freq Modules are also not configured properly, so I will have to swap them out as well. Sounds much better and is a step up from last week. If I can get the Xover setup right, I should be good.
I have a writeup available concerning the sub enclosure I made for the car:
http://www.win.net/audtatious/audio/...enclosure.html[/QUOTE]
Dman1989
19
Aug 17, 2015 03:44 AM
Team STILLEN
Aug 10, 2015 04:29 PM
MikesChevelle
Aug 6, 2015 11:36 AM
