4th gen antenna adapter + window antenna
Old Apr 13, 2004 | 12:04 PM
FLO_BOY's Avatar
hey there --
I replaced my HU and in order to hook up the antenna input, I had to buy
an adaptor as the Maxima has two antennas (and two prongs in the stock
antenna connector).
From what I've heard, when I plug in the adapter only the power antenna
will be hooked up and the window antenna will not be connected...BUT, I need
the opposite to happen -- so that the window antenna is connected and the
power antenna is not connected.
any ideas???
THANKS!!!
FLO_BOY
Old Apr 13, 2004 | 12:18 PM
Teameyekon's Avatar
bypass all of that and just rewire the window antenna straight to the HU and do away with the other antenna
Old Apr 13, 2004 | 12:29 PM
FLO_BOY's Avatar
OK, the other antenna has been "taken care of"...
but, how do you propose I rewire the window antenna?
FLO_BOY
Old Apr 14, 2004 | 07:49 AM
FLO_BOY's Avatar
BUMPity BUMP BUMP
Old Apr 14, 2004 | 10:38 AM
Teameyekon's Avatar
Good question...I will have to get back to you on that one. I will need to be in my car so I can remove my HU to get a better idea of what you are trying to do.
Old Apr 14, 2004 | 11:57 AM
FLO_BOY's Avatar
whoa! no need to take the car apart -- thanks tho!
basically, the stock antenna wire has two prongs which gets inserted
in the adapter...on the "out" end of the adaptor is the standard single
prong...
I'm gonna look into installing it tonight...maybe my original source was incorrect
as to the disablement of the window antenna, because, frankly that makes very
little sense.
G.
FLO_BOY's Avatar
prong...
little sense.
FLO_BOY
MAXSE5SPD
Sep 17, 2022 04:00 AM
The Frye
Feb 3, 2019 08:34 AM
Lowered_a33
Sep 1, 2015 07:49 PM
