Preamp Voltage ?
Old Apr 16, 2004 | 10:47 AM
WindFall's Avatar
Preamp Voltage ?
Would i be able to tell the difference between a head unit with 2.2v outputs and one with 4v outputs? Theyre preamp straight from the HU.
Old Apr 16, 2004 | 11:27 AM
MannyNJ2k2max's Avatar
yes....more sq ....but at the same time will pick up dirt in your signal easier
Old Apr 16, 2004 | 11:56 AM
slickrick's Avatar
with 4v you amps gains should be lower and thus should send a "cleaner" signal. but these days it seems everyone claims h/u dont put out the preamp voltage and such. but either way, 4volts is better.
Old Apr 16, 2004 | 04:39 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Pay more attention to the resistance than the Voltage. Most manufacturers are now 4-6.5Volt. With 200+Ohm resistance. Eclipses lower line 2.8Volt is easily comparable with most other 4+volt.
Yes you will tell a difference.
--Don
Old Apr 16, 2004 | 11:35 PM
nghtfthlngknvs's Avatar
definately. sadly, my old pioneer only puts out 2.2 get a HU with at least 4v preouts you WILL notice a difference
Old Apr 17, 2004 | 05:22 AM
friendhasmax's Avatar
yea look for the lowest possible output impedance...the lower the impedance, the closer the unit's OP-AMP's are to ideal OP-AMP's (which is a good thing)
Old Apr 17, 2004 | 08:54 AM
djslinkyz's Avatar
what's a good impedance range? my panasonic puts out 5V at 60 ohms
Old Apr 17, 2004 | 11:31 AM
that's fine
Old Apr 18, 2004 | 08:44 PM
WindFall's Avatar
many thanks you guys, you've pretty much made my decision on what to go with next
AaronL
Nov 15, 2020 11:52 AM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
18
Sep 22, 2015 11:39 AM
