How Did U wire your remote wire????
Old Mar 22, 2001 | 05:15 PM
BRIGBOY's Avatar
Does anyone have their remote wire spliced in with the power antenna wire so it still goes up when the cd player is turned on?
Is this dangerous to the amp?
As of now my remote is run directly to the amp, I left the power antenna wire free for now. But I get *** reception so I am wondering options for hooking it back up.
I dont wanna hurt my amps.
Old Mar 22, 2001 | 10:04 PM
CanuckAMP's Avatar
You should actually have the power antenna trigger wire connected to the power antenna trigger at the back of your deck. If you've got an aftermarkiet headunit without a power antrenna trigger then you can use the remote output that would feed your amps.
Old Mar 22, 2001 | 10:21 PM
Matt93SE's Avatar
STFU n00b!
And no, it won't hurt anything to wire it as Canuck said. that's the way 90% of stereo installs are done.
Old Mar 24, 2001 | 05:38 AM
nubiannupe's Avatar
OG Maxima.org Member
If U go that route, however, I would suggest using a relay to step up the voltage a bit. It's been my experience that this wire is usually only rated to handle so much of a load. Although, for normal (non-competition) purposes, you should be fine.
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
