custom trunk...supplies and materials
Old Apr 27, 2004 | 04:14 PM
craig10114's Avatar
so im getting ready to put in a new custom trunk into my max....got rid of the solo baric setup and picked up a whole new power acustic/jl setup
2 420watt amps (pa)(one for each sub)
1 400 watt amp(pa) for the interior
2 jl 12w3V2 subs
now im gonna be doing the intire trunk completly custom but im nto sure on what materials to use or even the prices on them
the mdf is basic but i want this to look really good so instead of carpet im trying to decide between
-twede
-valor
-vinyl
or suede
first off does anyone know anywhere online or in the Long Island area where i can pick up these materials and how much they usually run? also i want the sides of the trunk to be kinda padded under whatever material i use so im thinking about putting down a layer or carpet padding. has anyone does this before? and if anyone has what was your opinion on the final product?
the final design of the setup is still in the works but it should definitly look awsome when i finally finish all of it.
~Craig
Old Apr 27, 2004 | 06:13 PM
Maxima Dan's Avatar
Can't really help out with a whole lot since I am on the wrong coast. But I can make one suggestion and that is to try and use a good grade of plywood (Birch or Oak) instead of MDF. Nothing against MDF but man is it heavy.
Old Apr 27, 2004 | 06:39 PM
BBOYSTEVIE's Avatar
Back from Hibernation
Or if you really wanna go custom, fiberglass. Once you learn the wonders of glassing, you won't really think of a MDF setup as too "custom".
Anyways, for those choices in tweet/vinyl... check www.selectproducts.com
Old Apr 28, 2004 | 07:35 AM
SzeMan4's Avatar
Yeah i used mdf it is heavy but like 20 bucks for a sheet. I liked using carpet cause it matches the side of the trunk the gray sides. When i get off campus into a better place where i can open my trunk and not worry about people getting ready to jack my stuff i'll show you my custom setup.
Old Apr 28, 2004 | 08:01 AM
friendhasmax's Avatar
2 jl 12w3V2 subs
-twede
-valor
-vinyl
or suede
~Craig
look for a store called Ragshop...they have a lot of fabrics such as vinyl and other fabrics...i have one here in queens....there shoulld be one on long island...
www.ragshop.com i believe is the website..just do a store locate...selectprioducts.com is too expensive
Old Apr 28, 2004 | 11:46 AM
craig10114's Avatar
yea select products was a bit expensive but they definitly do have all the supplies im going to need
as for the post about matching the side carpet all of that is coming out, im laying down carpet padding and heat molding the vinyl onto that so its the new liner for the side of the trunk...hopefully it will open up some extra room in their for me as well but it will definitly increase the looks
Old Apr 29, 2004 | 02:58 PM
Playero's Avatar
Sanduguero
Craig There is a store call Jo-Ann Store (516) 333-7961 They sell all kinds of fabrics Check them out they are on old country road 530 i think...
Playero
Old Apr 30, 2004 | 04:29 AM
superblack98se's Avatar
I got Baltic Birch wood for my subwoofer enclosure for 20 bucks for all the wood i needed...my local home depot put it in the scrap wood section, and was selling it around 4 bucks a piece, my box isnt a small box either, its 3.89 ft^3. Just check out home depot, they put so much good wood in the scrap section, I built two subwoofers, one of them being 5 ft^3 for my home.
Apr 16, 2020 05:15 AM
mpbclutch33
Sep 21, 2015 01:54 PM
carid
Sep 17, 2015 05:00 AM
carid
Sep 9, 2015 05:06 AM
Maxboy23
Sep 4, 2015 06:04 PM
