Need help with PAC adapter
Old May 2, 2004 | 11:53 AM
imxelite's Avatar
Will I had the aftermarket adapter put in my car that allows you to keep you steering wheel controls. But the buttons don't work like I want them to the trip works fine but the mode and the different track button doesn't work right. Is there any way I can change this without taking apart the dash again?
Old May 2, 2004 | 10:07 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Did you have an audio shop install this or did you do it yourself?
If you had an audio shop install it, I'd take it back and have them redo it.
If you did it yourself, might want to double-check the wiring.
Old May 3, 2004 | 06:21 AM
Kojiro_FtT's Avatar
The wiring is not wrong, but the programming is. If you had a shop do it, take it back and tell them it's not right. If you did it yourself, then you know how to open it and reprogram yourself.
Hint: You can also program it so that button combinations do other things. Like on mine, I made both volume buttons together change source. And both track buttons together change disc.
magiconthetire
Oct 26, 2015 09:03 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
