upgrading subwoofer for bose systems
So I told myself that when I got this car, I wouldn't do anything to it. Keep it stock for awhile....well, I can't help myself.
I'm an upgrade junkie and I can admit it!
So, I'm looking to upgrade the bass a little. The stock system sounds pretty good for stock but, I'd like to get more bass. The 8's give you some bass but, it's like a tease for me because I'm waiting for my seat to give me a massage!
Anyway, I've come up with a pretty cool idea. I'm planning to make a mdf/fiberglass box to fit into one of the side to the rear of the trunk. Kinda like the JL audio stealthbox for the previous maximas. A 10" sub, maybe even a 12" sub might be able to fit in there. I would use the other side of the trunk to house the new amp. I'm thinking that I will finish the front of the box with carpet to match the trunk or I can paint it to match the car. I don't know yet...
I just wanted to throw this out there and see what you guys think of it. Maybe someone else has already done it...I don't know. If it has already been done, can someone point me to a website or pic. Thanks
PS - I guess this upgrade could be for both the bose and the stock system.
I'm an upgrade junkie and I can admit it!So, I'm looking to upgrade the bass a little. The stock system sounds pretty good for stock but, I'd like to get more bass. The 8's give you some bass but, it's like a tease for me because I'm waiting for my seat to give me a massage!
The best way to go about this and keep the stock Bose stereo is add a PAC OEM1 Bose adaptor. We sell them to the 4th and 5th Gen Maxima people that just want to add a single 10 or 12 to give it some more bottom end.
The PAC adaptor gives you 4ch of RCA outs. It's not a crappy hi-low converter, but it intercepts and converts the balanced line level signal from the deck and gives you a tradtional unbalanced RCA output.
No, that will not work. The bose amp uses a balanced line signal whereas amps w/ RCA's are unbalance.
Or you can use a hi-low converter which is a ghetto way of getting RCA's. You will loose a lot of signal quality using this method.
Originally Posted by ABS
Well, I know it's a high level unbalanced signal from the HU to the Bose amp, but, are you certain about the line from the Bose amp to the Bose subwoofer? I nearly positive that I've read about people tapping directly into that line without any ill effects.
he wants $80~$100 for just installation. I kinda wanna install amp/sub by myself, but I'm inexperienced and it's freaking cold outside...still thinking...
More pix:http://www.cardomain.com/ride/636944/5
Originally Posted by VTmaximaVT
so where can i get the PAC OEM1 Bose adaptor? my installer said he's gonna tap into rear speaker wires and get signals from there. he did amp/sub installation on my roommate's QX4 with bose system, he used some kind of adaptor...i'll get a pic of it tomorrow or sometime soon.
Some people have gone the pre-fab route... they got either a basslink or bazooka tube and tapped into the rear subs. The PAC adaptor you can get probably on ebay or post a WTB in the 6th gen classifieds.
Sounds like a great idea. Let us know how it turns out. If you go with fiberglass, I would probably just have it painted the same color as the trunk interior. I really like the fiberglass look, it's just a little more expensive. I have been considering a fiberglass enclosure for my last sub. The vinyl for me has worked out nice, but fiberglass is the shizznizzle, ya' hurd!!! Good luck!
PEACE OUT
PEACE OUT
I know its an old thread but none the less. Dozens of Maximas and Many years of installs beg to differ with your opinion. Running a direct RCA out from low level of the HU works perfectly fine without and issues.
I had an '04 Altima w/ the Bose Premium system. I wanted crisper bass so I installed an Infiniti Basslink into the trunk and tapped into the signal lines going into the rear Bose amp. Worked great. The nice thing about the Basslink is it's small eough to move around the trunk until you find the right bass wavelength response in relation to the driver's seat.
I now have an '06 Maxima (long story) w/ the Bose premuim sound system. The bass on this system is a little better so I've decided to not to install another basslink. However I have found the highs to be flatter than my liking and would love to find a way to add some tweeters into the upper doors or A pillars.
^ that is the adaptor. Scoche also makes one you can get for a bit less money. The PAC one costs around 59 or so. I am buying the one from Scoche tomorrow and going to install later this week or early next week with two amps, components and subs.
SLC4 4 channel line output converter. Not bought yet, but will in a few hours (ebay). I'm going to try this one and if it doesnt work well I may consider others. Depending on your pockets/needs Fosgate has a new signal processor out called the 3Sixty. Its around 300 dollars but its pretty sweet. If I had the money I would consider but I dont, so no need. It is supposed to be the next generation in using the stock head unit and adding aftermarket speakers/subs/amps. And its bluetooth.
you are wasting your money.
The bose sound system doesn't sound very good in the first place and all you're doing is upgrading the bass... Buy a hi-low converter (15$ on ebay), it'll work just fine! I've installed these in MANY Maximas which kept the bose speakers and you won't be able to tell the difference.
Take the extra money and invest it in a better amp and drivers, you'll be glad you did.
foudn the PAC oem2 really cheap.. thought i'd post it here.
so use this to tap into the rear stock bose speakers input wires, then connect this to the new amp right?
OEM2 for $27.04
http://www.thebettersource.com/servl...prod=3593&dw=1
OEM2 for $27.04
How many times does this RCA method need to be repeated for people to actually listen?
those need to be updated then...
Originally Posted by Pearl96Max
No, what you can do is splice RCAs into the preamp level of the signal.
Originally Posted by evil_spork
the sticky's say that you need to use the PAC adapter.
so how exactly do i do this? any pictures or anything? the stickys dont say anything about this.
Take a pair of MALE RCA's. Cut off the end leaving about 6 inches of wire. Strip the two wires on each plug. Use those 4 wires and splice them INTO the speaker leads. Plug your PREAMP wires coming out of your HU into these male wires. Done. You're lucky I'm drvnk and in a good mood to actually type all that out.
Not the speaker leads on the rear deck. The sub. Where is the sub in the 4th gen anyway?
Actually the stickies have the right info. Some of it I wrote myself. They have been used for a reference point Many times over without fail.
Want to add a sub (or additional speakers) to your Bose amp?
http://forums.maxima.org/showthread....hreadid=193490
http://forums.maxima.org/showthread....hreadid=118180
the second thread says to use a PAC adapter.
the post below that in the FAQ:
Adding RCA outputs / Amplifiers / Subs to 95-2003 Bose
Want to add RCA outputs (with optimal sound quality) to the BOSE HU (95-2003)?
Use the PAC AOEM-NIS2. It is completely plug and play and provides a remote wire lead, a pair of front channel RCA outputs, and a pair of rear channel RCA outputs. Eliminates several of the issues involved with using a Line Output Converter.
Currently the best price is $59.95 shipped, available here:
http://www.affsave.com/pac5.htm
those are the only posts in the FAQ section regarding adding a sub to the bose system.
so again i ask, where in the stickys is a good explination of how to do this? could you please help this time instead of wasting both our time and bandwidth?
It will connect to the back of you factory head unit. Look it up on Ebay and you will understand. It goes from your head unit to the OEM box then back into the cables that run to the amp. I got mine about a month ago. It's either you buy one, or splice a pair of RCA cables into the output of you amp. They sound very similar, the PAC OEM1 is a little better/cleaner though.
