need help with 4 gauge wires
Old Jun 16, 2004 | 04:19 PM
GodFather's Avatar
Made in Taiwan
i am trying to run a 4 gauge wire from the battery to the car. what is the best way for the wire to "get inside" the car? do i go through the electric route of the firewall? i really don't want to mess up the rubber insulator that takes in all the wires.
I used to run up the wire through the driverside fender, but it looked pretty ghetto when i open the door because it just appears right on the door step by the hinge; besides, opening and closing the door too many times, it cut the rubber covering on the wire and it burned a hole in the hinge area. please help!!! any other ways?
Old Jun 16, 2004 | 04:50 PM
craig10114's Avatar
if your auto then tap the clutch plate, its a weird shaped peice thats up and to the left of your brake pedal, if you pull the vinyl off just put a drill to the metal and go...if your manual then im pretty sure you go from somewhere behind the gas pedal but im not positive so dont take my word for that
Old Jun 16, 2004 | 05:25 PM
Terran's Avatar
There's an answer to this in one of the faqs (probably a 4th gen one). Behind one of the fender liner's or something maybe?
Old Jun 16, 2004 | 09:44 PM
suprropmp's Avatar
problem with that is that the wire ends up under your car somewhere.. how are you supposed to bring it up to the battery when the engine compartment is so packed?
Old Jun 17, 2004 | 05:48 AM
MacAlert's Avatar
The wire goes into the engine compartment. It does not go under the car. All you have to do is reach in the car and pull the wire through.
Old Jun 17, 2004 | 10:11 AM
suprropmp's Avatar
Ok, here we go again. After removing that piece of vinyl from where the clutch is supposed to be, I get this:
what is that screw looking thing sticking out? Should I just drill through it?
Old Jun 18, 2004 | 04:10 AM
GodFather's Avatar
Made in Taiwan
hey, thanx pimp, that really helps me alot. i think i know how already. good work...
Miket2006
Mar 1, 2021 03:55 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
