2k2 Non-Bose--Basslink Problem!!
Old Aug 3, 2004 | 10:14 AM
SgtSchulze's Avatar
Burn Dust. Eat my rubber.
My Basslink just quit working. It has power. No blown fuses. I checked the ground with my Fluke and it seems solid. It auto turns on and everything just doesn't fire up. Nothing's really happened other than some wet golf shoes in the trunk overnight. Could that be the problem?? I also notice that my rear channels seem a little fuzzy (I'm tapped in to the rear for signal etc...). Those connections are soldered and shrinked. The only place I haven't looked is under the rear seat where I ran the wires. What would happen if one of those wires was grounded to the chassis or something??? Is there any way to test the Basslink to see if it actually works?? It could be my factory head unit messing up. Thanks
Old Aug 3, 2004 | 01:35 PM
nismos14's Avatar
§è~® f®ÈÄk
try switching the signal wires around or trying the other input if ur using the highlevel adapter, see if that makes any difference, otherwise it sounds like the amp or sub ** COULD ** be blown
Old Aug 4, 2004 | 06:10 AM
SgtSchulze's Avatar
I think the amp inside is blown some how. I'm going to try replacing the Basslink tonight. I'm almost ready to just put in a "real" system instead of this factory shyte. Thanks
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
