another speaker/amp question
Old Apr 5, 2001 | 11:30 AM
loudmaxima's Avatar
should i just do coaxils in the rear deck or seperates??? (there's nothing there at the moment) i already have like $2500 dumped into the front and i dont wanna be cheap on the rear >> should i just do it with seperates??
also i wanted to get another amp (orion hcca 225 for all the tweeters and the horns) should i bother doing that also??
>pioneer 8200
>precision power deq230
>illusion 6.5s/tweeter in doors
>illusion 5.25s/tweeter in kicks
>crystal compression horns under dash (soon to be illusion compression horns whenever i get around to it)
>orion hcca 250g4 amp
Old Apr 6, 2001 | 06:17 PM
94SUPERMAX's Avatar
I think that you should go with the seperates in the rear, and about the amp it's your call if you need it.
Old Apr 6, 2001 | 08:14 PM
Dustyroads's Avatar
Most people would say just do coaxials and I agree. If you do a components set then you need to find some place to mount the tweeter and with a coaxial you have the tweeter already take care of. In a car the is set up for SQ, the rear speakers are simply for fill. They just add depth to your soundstage. Some would argue that a coax is even too much, just use a simple speaker. I would have them play as a mid-bass/mid-range speaker. For the second amp question,
I guess I'm strugling to see how the setup is wired already. You have a 5.25, a 6.5 and a set of horns all up front. How is the amp that you currently have wired to the speakers? I would guess that you are running one set to the horns and the other to both the 5.25 and the 6.5. If this is true then you need something else to power the rear speakers. I would personally go with a nice two channel. Just my 2 cents. Good luck and post pics when you get it done. I'm interested to see how the horns look.
Old Apr 6, 2001 | 10:04 PM
DCmax's Avatar
Go with some coaxials
Components in the rear are a total waste unless you are Shaquille O'neal or something and your ears are basically in the back of the car all the time.
Dustyroads made a good point about mounting the tweeter when you put components in the rear deck. A friend of mine had components in the rear of his 240sx and he had these ugly almost tower like things holding up the tweeter.
When you are cruising around really bumping your system, if you dont already know, Max rear decks rattle like crazy (atleast my 96 does) and if there were people sitting in your back seats with the sub kicking, they wouldnt really be able to appreciate the clarity of components due to the subs.
Save your money
Good Luck
Old Apr 6, 2001 | 10:39 PM
GarthG's Avatar
How much do the horns get in the way on the driver's side, and do they often get kicked on the passenger side? I like the way the horns sound, but installation in a Maxima just reall isn't possible without a lot of problems. . .
Old Apr 7, 2001 | 06:31 AM
loudmaxima's Avatar
I guess I'm strugling to see how the setup is wired already. You have a 5.25, a 6.5 and a set of horns all up front. How is the amp that you currently have wired to the speakers? I would guess that you are running one set to the horns and the other to both the 5.25 and the 6.5. If this is true then you need something else to power the rear speakers. I would personally go with a nice two channel. Just my 2 cents. Good luck and post pics when you get it done. I'm interested to see how the horns look. [/B][/QUOTE]
orion hcca 250:
2x50 @4ohm
2x100 @2ohm
2x200 @1ohm
2x400 @.5 ohm <<stable
Old Apr 7, 2001 | 06:40 AM
loudmaxima's Avatar
driver side: just trial and error mounting under the steering column dash peice, i already have kick panels so it's not to much of an inconvience on the passenger side every now n then but jus gotta be a **** about it sometimes ;] >>
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
